Old 07-10-2012, 05:05 AM   #1
magtec
magtec will become famous soon enough
1995 SW2
Default windshield washer
just noticed that the windshield washer stopped working on my wagon. the wipers function fine otherwise, but neither the wipers nor the washer pump turn on when the stick is pulled. bad switch?
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 07-11-2012, 05:22 AM   #2
magtec
1995 SW2
Default Re: windshield washer
bump.
Old 07-11-2012, 01:45 PM   #3
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
This is going to take a little work to check.Get to the wiper motor and remove the electrical connector.Now probe the brown wire at the connector with your red lead from the multimeter and the black lead to ground set the meter to the ohm scale.Turn the switch to the wash setting and observe the meter there should now be a different reading.If the meter shows no difference in reading the switch is faulty.Now if you saw movement at the meter then there is a high probability that the motor slash microprocessor is faulty.You can confirm this by replacing the electrical connector and checking for voltage at the pink wire at the washer motor.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-15-2012, 10:43 AM   #4
ObelixDeGaul
ObelixDeGaul is on a distinguished road
Richpin thank you for all your videos. They are a real lifesaver for newbs like me. I really really appreciate all your contributions. The only reason I am writing in this thread is because I haven't seen you post lately.
Obelix DeGaul
1996 SL2 Manual
1996 SL2 Auto
Add to ObelixDeGaul's Reputation
Rate the quality of this post and help ObelixDeGaul reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ObelixDeGaul is offline   Reply With Quote
Old 07-15-2012, 01:24 PM   #5
2NDSOUT
2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough2NDSOUT is a jewel in the rough
2NDSOUT's Avatar
1999 SL
Is this for the front wipers or the rear wiper?
Check the washer wiper motor that is in the wiper fluid tank.
I would also follow Richpin's post as well.
What is the condition of the stalk on the steering column?
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 07-15-2012, 03:17 PM   #6
magtec
1995 SW2
front.
stalk and wipers function properly otherwise.
haven't had a chance to check anything yet.
Old 01-05-2013, 08:52 PM   #7
magtec
1995 SW2
thanks to everyone for the responses (especially richpin, great info!)
so, this issue got pushed to the rear burner. i've since discovered that if i pull the stalk back just short of the stop that the washer and wipers turn on and function like they're supposed to. so the new question is: what year wiper stalks are compatible with my '95 sw2?
Old 01-05-2013, 09:12 PM   #8
You should be able to use any 95 up SW combination switch.
Add to ssicarman's Reputation
Old 01-05-2013, 09:12 PM   #9
Rockauto says '95-'98 or '95-'01 SW's (ACDELCO branded part says '95-'98 and ACDELCO should be stock/OEM), but I wouldn't be surprised if it's really a year specific part.
Old 01-05-2013, 09:40 PM   #10
Nothing year-specific about the combination switch. Does have to be for a wagon, of course. First thing I'd try is to figure out just what moves in the switch when you activate the washers, and hit that with aerosol electronics cleaner. Long-shot, but it might just restore normal op.
Add to madpogue's Reputation
Old 01-05-2013, 10:51 PM   #11
magtec
1995 SW2
cleaning the switch was a thought. guess it depends on how much motivation i have.
Old 01-06-2013, 12:00 AM   #12
The price of a replacement will have have a significant impact on that "motivation", I reckon.....
Old 01-06-2013, 09:39 AM   #13
magtec
1995 SW2
there are three compatible SWs at the upull yards here, shouldn't be exorbitant.
http://www.upullrparts.com/prices
Windshield washer comes on with wiper steinhau S-Series Tech 3 04-13-2017 02:41 PM
Windshield Washer Nozzle MRink Vue General 35 04-10-2014 04:27 PM
Windshield Washer Buggerall 2008 Vue 2 02-22-2011 06:27 AM
2002 SL1 - Windshield Washer won't shoot the juice on the windshield. HELP! 2002SaturnMan S-Series Tech 4 12-07-2009 10:21 AM
Windshield washer gremlin Scooped S-Series Tech 2 05-24-2006 07:57 PM
