Old 07-08-2012, 10:40 PM   #1
AndreasChen
AndreasChen is on a distinguished road
Default Trunk Leak / Inner Quarter Sealing Question
Hi all,
This question is a continuation of this accident:
http://www.saturnfans.com/forums/sho...d.php?t=158106
After taking off all the plastics, I found there are deeper damages to the inner quarter panel. As shows in the picture:
This is something I cannot correct by myself, so I sent to a body shop. The shape was corrected, but it started to leak. I took the bumper cover off again, and found the black sealing is damaged. I assume it was damaged when the body shop was reshaping the inner quarter panel, because there was no leak between the accident and the repair.
Now it leaks into the trunk even when I spray a little bit of water onto that seal
My questions are : what is the formal name of that black seal? Is it manageable with moderate amount (say <$200) of tools/supplies to repair that at home?
Thanks a lot!
02 Saturn SC2, noisy, trying to quiet it down...
Add to AndreasChen's Reputation
Rate the quality of this post and help AndreasChen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AndreasChen is offline   Reply With Quote
Old 07-16-2012, 08:19 AM   #2
AndreasChen
Default Re: Trunk Leak / Inner Quarter Sealing Question
Temporally solved the problem by reinforcing the seal with a lot of black silicon. So far so good but not sure how long it will last
Old 07-16-2012, 10:18 AM   #3
2006 ion2
2007 ION-2 Sedan
Seam sealant. It's purpose is to ensure a leak free car. It should be able to be applied with a caulking gun, but out may need to be a powered caulking gun like we use on aircraft.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 07-16-2012, 02:39 PM   #4
AndreasChen
Any comment on the black silicone repair?
Silicone seems to work, but the question is if it's going to last. If not, I'd better start doing homework on the seam sealant
Thanks!
Old 07-16-2012, 03:40 PM   #5
2006 ion2
2007 ION-2 Sedan
it's not the same quality product. the seam sealant is usually a 2 part product, the kind I've used uses a 2 tube gun using pneumatic pressure to drive the sealant out, or has the second part in the tube, but you need to inject/mix it and use a powered single tube gun to get it out. sealant isn't what I would call "cheap" or "easy" to work with because of the 2 part system and the viscosity of it.
the seam sealant will actually retain the integrity of the seam, where the silicone will only fill the hole, one doesn't in any way equal the other. unfortunately, I don't have any just laying around, or I would send some to you, but at least try to find the single tube you need to mix, it's going to be the most possible for you to work with at home. also, try to find as many things to do with it before you mix it, it hardens quickly, and is quite expensive. expensive enough we always went around the whole hangar making sure NOBODY else needed any, and coordinated the time it was mixed if they did. also, buy the smallest quantity you can.
once you decide what your options are, let me know, there are some things you can sometimes do to get around needing a special gun.
2007 Saturn Ion 2
Old 07-16-2012, 09:57 PM   #6
AndreasChen
I did notice the factory sealant was mechanically much stronger, so I only used silicone on top of factory seal to fix holes (instead of removing any old sealant). The silicone repair is still relying on the old structure.
It looks like the seam sealant is not as straight forward as I thought, and I am kind of short in time to do more homework on it. Let me put this thing aside for a few month and keep this thread in my bookmark folder. I will come back a little later to this issue
Thank you very much 2006 ion2, it is very helpful
98 SC1 Trunk Leak mattelderca S-Series General 16 05-03-2014 10:45 AM
Thermostat Sealing Question Ramics S-Series Tech 7 03-18-2012 05:21 AM
Trunk leak fix! MJD112379 Aura General 13 07-24-2008 12:58 PM
Power Window Sealing question... gm7 S-Series Tech 4 04-17-2004 07:26 AM
SC2 Trunk lid sealing/Gaps Flyguy405 S-Series Tech 2 12-10-2003 09:43 PM
