Old 07-06-2012, 04:42 PM   #1
Integral
Integral has a spectacular aura aboutIntegral has a spectacular aura aboutIntegral has a spectacular aura about
Dazed Odometer and Speedometers Issues
Hi,
I have a '93 SC2 5sp w/~100k
A few days ago I notice the following:
1. The odometer continuously turns, then stops completely for a minute or so, then turns continuously. The result is that a 5 mile drive is recorded as a ~30 mile drive.
2. The speedometer is intermittently erratic at freeway speeds (above 60 mph). It reads correctly at lower speeds. On the freeway the needle will swing back and forth from ~60 to ~80, then read correctly/steady for a few moments then back to erratic.
About 1 1/2 years ago I replaced the odometers gears with ones from a junkyard because the odometer had stopped working completely. The odometer has worked accurately until now. I wouldn't think a broken gear wheel would cause it to turn continuously, rather it would simply stopped altogether.
Any advice on the culprit (VSS, Cluster part, etc.) would be appreciated.
Thanks.
Add to Integral's Reputation
Rate the quality of this post and help Integral reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Integral is offline   Reply With Quote
Old 07-06-2012, 08:22 PM   #2
2NDSOUT
2NDSOUT's Avatar
1999 SL
Default Re: Odometer and Speedometers Issues
Sounds like issues with the odometer motor/and/or gears. The speedometer reads the speed via electrical impulses via the electrical circuit film that attaches to the instrument cluster itself.
What is the status of your electrical system as well?
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 07-07-2012, 12:32 AM   #3
Integral
Post Re: Odometer and Speedometers Issues
The electrical system, as far as I can tell, is fully functional. I have replaced both the battery and alternator about a year ago.
Since both problems (Speedometer and Odometer) presented at the same time, it makes sense that both are the effect of a single cause.
Hopefully this is is a known problem (eg., ETCS) and has a ready solution.
Old 07-07-2012, 05:54 PM   #4
Integral
Question Re: Odometer and Speedometers Issues
Any advice on what, and how, I can check for the problem?
I don't have a plan of action, other than to pull a cluster (if I can find one) from a junkyard and hope for the best.
Old 07-08-2012, 09:48 AM   #5
2NDSOUT
2NDSOUT's Avatar
1999 SL
My guess would be that the Odometer motor has failed and the circuit film on te back of the cluster has come loose, or the contact points that send impulses to the speedometer have become dirty.
Even if you pull the dash out of a JY car- there is no guarantee that the JY dash odometer and speedometer would work.
Just throwing this out there- why not pull your current dash and see if there is something loose or broken first before making a trip to the yard, at least you wouldn't be spending the money on a JY part and gas getting there if your current setup just needs to be checked/cleaned.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 07-09-2012, 12:40 PM   #6
mansaturn
mansaturn is on a distinguished road
whatever you do, don't waste time pulling clusters out of yards to try to find a good gear. you can buy new gears on ebay that are well worth the money. if you are lucky enough to find an unbroken original gear in a junkyard, it won't last long anyway because it's already brittle. it's a colossal waste of time. as stated above, take yours apart, and if it is the gear or gears, replace them. if the gears are ok, you may have a speed sensor problem or possible faulty speedometer/odometer board.
Add to mansaturn's Reputation
Rate the quality of this post and help mansaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mansaturn is offline   Reply With Quote
95 SW2 issues, Speedometer out and the Odometer? destro5 S-Series General 3 12-31-2011 05:14 PM
2000 Saturn Lw2 wagon speedometer/odometer issues JediMasterMatt L-Series Tech 14 11-27-2011 01:22 AM
93 SL2 Odometer and fuel sender issues stormtracker S-Series Tech 13 10-23-2011 02:11 PM
Tires, Wheels and Speedometers Titanium48 S-Series General 10 11-20-2005 09:31 AM
sl odometer/dash light issues veganboyjosh S-Series Tech 1 10-26-2005 08:38 PM
