Old 06-23-2012, 03:28 PM   #1
02 Dawg
02 Dawg is a jewel in the rough02 Dawg is a jewel in the rough02 Dawg is a jewel in the rough02 Dawg is a jewel in the rough
02 Dawg's Avatar
2002 VUE 3.0L
Default PO 700 Code Won't Clear
I was driving my 02 Vue and the alternator stopped working so I drove the Vue home and the car was loosing power and then the battery went dead. I have a code PO700 Transmission Control System Fault
that will not clear with the Snap-on scanner I have. Any ideas on how to clear this code?
Thanks,
Add to 02 Dawg's Reputation
Rate the quality of this post and help 02 Dawg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
02 Dawg is offline   Reply With Quote
Old 06-23-2012, 03:45 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: PO 700 Code Won't Clear
Thanks,
Can we assume you fixed the alternator - the battery is fully charged - and you've driven the Vue several miles?
P0700 is set when the TCM advises the ECM something in transmission is not right.
You may need to operate the Vue for a few warm-up cycles until the TCM is satisfied all is well.
Old 06-23-2012, 03:48 PM   #3
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
Thanks,
I found the problem! I had to go into the transmission part of the scanner and found a low voltage code that I had to clear. Then went back to the engine part of the scanner and cleared the PO700 code and now the SES light is off. Awesome
Old 06-23-2012, 03:53 PM   #4
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
Yes I had the original alternator rebuilt for $85.00 I found another code in the trans part of the scanner and cleared it then cleared the PO700 code and no more SES light.
Thanks for your help,
David
Old 06-23-2012, 04:02 PM   #5
far2grumpy
far2grumpy's Avatar
David
David ... you've had a tough week - but it appears you beat the little guy back into shape - for now. Congratulations for the perseverance.
P0410 code, changed ECTS, code back mattwithcats S-Series Tech 1 06-24-2011 06:40 PM
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) DJboozeAlot S-Series General 3 03-18-2011 09:26 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 05:17 PM
Time between code clear and SMOG RobertGary1 S-Series Tech 5 02-28-2008 05:25 PM
Possible Group Buy on CLear corners & Black Clear corners ShinyYellowVue Vue Mods 18 10-02-2006 04:13 PM
