Aura General Photos
by Catbert
AURA - Member Photos
588 photos
198 comments
by RON HOHIMER
588 photos
198 comments
by peteraura
588 photos
198 comments
by zallen777
588 photos
198 comments
Old 06-20-2012, 01:04 AM   #1
aurafan2008
aurafan2008 is on a distinguished road
aurafan2008's Avatar
2008 AURA XE
Default How difficult is it to install fog lights.
I have an 2008 XE and it did not come with factory fog lights. I was hoping to find some OEM factory lights. I am just in the thinking stage right now. I was wandering if anyone knew how difficult it would be to install them? For example would the wiring already be behind the bumber to tie the lights into? And would you have a place on the dash to mount a switch or does it work off of the light switch? Or would you have to run all new wirirng?
Also if anyone knows of any aftermarket lights that look or are similar to the original fog lights let me know.
Thanks,
brc
Add to aurafan2008's Reputation
Rate the quality of this post and help aurafan2008 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aurafan2008 is offline   Reply With Quote
Old 06-20-2012, 08:35 AM   #2
golftango
golftango is on a distinguished road
golftango's Avatar
2009 AURA XE
Default Re: How difficult is it to install fog lights.
The wiring is not there, you'll need to run the wires.
You'll need an aftermarket switch, or you can get a factory switch from a junk yard. Same switch as a Malibu.
It's not a difficult job if you're comfortable with wiring and schematics.
Do a quick search, this topic has been covered before with instructions.
'09 Saturn Aura XE
Add to golftango's Reputation
Rate the quality of this post and help golftango reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
golftango is offline   Reply With Quote
Old 06-20-2012, 06:36 PM   #3
aurafan2008
2008 AURA XE
Thanks for the info. But looks like my money will be going to lawnmower repairs after today .
brc
Old 06-23-2012, 03:09 PM   #4
Low Saturn
Low Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to all
Low Saturn's Avatar
2008 AURA XE
Originally Posted by golftango View Post
....or you can get a factory switch from a junk yard. Same switch as a Malibu.
You can also use one from a G6. But the Malibu one will illuminate blue and the G6 one red.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevy Suburban
-2008 Saturn Aura XE V6
Im out of EGR adaptors & ECTS connectors.
Old 06-23-2012, 07:22 PM   #5
DigitalSaturns
DigitalSaturns is on a distinguished road
or you can hard wire them to come on with the key and they'll be on at all times.
Add to DigitalSaturns's Reputation
Rate the quality of this post and help DigitalSaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DigitalSaturns is offline   Reply With Quote
Old 06-24-2012, 11:31 AM   #6
aurafan2008
2008 AURA XE
Just wanted to thank everyone for the info and suggestions.
brc
Old 06-24-2012, 03:24 PM   #7
motrhed79
motrhed79 is on a distinguished road
motrhed79's Avatar
What's wrong with the lawn mower???
Ford Senior Master Technician
Current fleet:
~02 SC2 Rebuild thread http://www.saturnfans.com/forums/showthread.php?t=181982
~00 F150
Saturns from my past ~95 SL1, ~97 SL2
Add to motrhed79's Reputation
Rate the quality of this post and help motrhed79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
motrhed79 is offline   Reply With Quote
Old 06-25-2012, 12:17 PM   #8
golftango
golftango's Avatar
2009 AURA XE
The VTi went. He's swapping it for a F23.
'09 Saturn Aura XE
Old 06-26-2012, 04:22 PM   #9
aurafan2008
2008 AURA XE
I had just got through servicing the lawnmower a couple of weeks ago. It is a Crafsman riding mower. Changed the oil and filter, bought new belts, spark plug, airfilter, fuel filter, blades, adjusted the brakes and clutch. I had mowed one time since I did all of this.
I was going to mow with it last week, so I put the battery on charge one evening. Went to the shop to unplug the battery charger and there was gas pouring out of the carb everywhere. I didn't know what was wrong. I took the carb. apart the next day cleaned it. I am assuming the float and needle valve got stuck. B/C when I mowed the first time I put some Seafoam fuel cleaner in with the gas. I think the Seafoam broke loose all the gunk and caused the float to get stuck. When the gas overflowed it got into the crankcase. So, I had to re-change the oil replace some of the parts I just bought. It is running fine now and I didn't have to buy a new carb.
Hope it keeps on running fine.
Thanks for asking,
brc
Help! Sub Install & No Dash Lights QCs_R4_Girls Ion Tech 7 04-19-2009 07:53 PM
How Difficult to Install Power Windows on a car with Power Locks? sandybright S-Series Tech 1 09-07-2006 03:25 PM
Is it difficult to install second oxigen sensor? Al Bear L-Series General 4 08-09-2006 11:12 AM
New Instrument Cluster; how difficult to install? usa4624 L-Series General 3 01-04-2006 12:12 PM
How difficult is it to install a hitch? mreloc Vue General 11 04-19-2003 01:55 AM
