Old 06-19-2012, 10:43 PM   #1
Mr Toad
Mr Toad is on a distinguished road
Mr Toad's Avatar
Default Ignition switch problem
2005 Vue fwd 3.5L
The ignition switch seems to turn easily to any position except ACC to LOCK. Also when I attempt to remove the key it will sometimes get stuck half way out. At this point I cannot turn the key, insert it, or remove it. I have to forcibly pull on the key to remove it.
I read through the Service Bulletin #06-02-35-016A about cleaning and lubing the Cylinder Housing but this doesn’t seem to pertain to my situation since it moves well to all positions except ACC to LOCK. Could there be a problem with the Park Lock?
How do I remove the Trim Cover under the steering column? I see screw holes at the bottom. What type of screwdriver do I need to remove these screws? Then what?
Add to Mr Toad's Reputation
Rate the quality of this post and help Mr Toad reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mr Toad is offline   Reply With Quote
Old 06-20-2012, 07:04 AM   #2
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
Default Re: Ignition switch problem
Originally Posted by Mr Toad View Post
2005 Vue fwd 3.5L
Do you have a brand-spanking new key to try?
Contact a local GM dealer to see if they can cut one using your VIN.
You should be able to "pop" the upper trim cover off by inserting finger in hole above the turn signal switch and giving a sharp tug upward.
The bottom trim cover is held in-place by three hex-head 5.5 mm (7/32)screws.
The transmission PARK cable is mounted on bottom of ignition switch ... its held in place with plastic clips and is generally either secured or falls free - I used a sturdy cable-tie once to keep it in place.
I can email service manual extracts to remove the key cylinder from the lock housing for inspection and cleaning. Send address by PM if interested.
BTW ... you might call a local locksmith to see what they think ... they could have parts (and skills) to make your Vue whole again at less expense than a GM dealer.
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
infamous ignition switch problem filmmaker Ion Tech 4 05-17-2009 04:46 PM
Balky ignition switch problem. Twincitytractor S-Series General 1 10-04-2008 07:51 AM
Ion ignition switch problem lpchick316 Ion Tech 2 09-01-2008 08:59 PM
ignition switch/fuse problem Mr Bhp Ion Tech 2 10-16-2007 01:50 PM
93 SL2 Ignition Switch Problem AndyS S-Series General 3 05-25-2005 11:50 AM
