Old 06-16-2012, 08:24 PM   #1
02 Dawg
02 Dawg is on a distinguished road
02 Dawg's Avatar
2002 VUE 3.0L
Default Heater Won't Stop
When I turn my thermostat to cool the heat still comes out like I have the heat on. Even when I turn the A/C on heat still blows out. Any ideas what could be wrong?
Thanks for any help.
Add to 02 Dawg's Reputation
Rate the quality of this post and help 02 Dawg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
02 Dawg is offline   Reply With Quote
Old 06-16-2012, 08:25 PM   #2
Tom92SCm
Tom92SCm will become famous soon enoughTom92SCm will become famous soon enough
Tom92SCm's Avatar
2004 VUE 2.2L
Default Re: Heater Won't Stop
When you turn the temp selector, is there the normal amount of resistance? Does it stop at the usual limits?
2012 Ford Escape V6 Limited AWD
2004 VUE 2.2L 5 speed
1997 Ford Explorer XLT 4x4
Add to Tom92SCm's Reputation
Old 06-16-2012, 08:30 PM   #3
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
No. It spins like a clock.
Thanks for your help,
Old 06-16-2012, 08:51 PM   #4
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
Heated coolant always flows through the heater core and amount of heat induced into air-stream is controlled by a damper door (cover) controlled by the air temp switch.
Yours could be disconnected behind AC panel or perhaps is disconnected from the door (or - gasp - broken ).
I tried to attach two files - one to replace (inspect) the air temp cable and the other to remove IP panel to get at the HVAC control. However, both exceed forum limits but I can email to you if you PM an address.
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
far2grumpy is online now   Reply With Quote
Old 06-16-2012, 08:54 PM   #5
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
The selector mechanism on the backside came off. Remove the window control "ring" around the gear shift and then remove the 4 screws that hold on the center pocket (or I think where the heated seat controls are on VUEs so equipped). Then, pop the whole center console trim bezel off. Then connect the selector mechanism to the bezel. You'll have to play with the knob to find out where the needs to be when connected to the mechanism. Hopefully the hooks that secure it didn't break.
Old 06-16-2012, 09:02 PM   #6
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
Thanks for your help. I will check it out in the morning. Thanks again
Old 06-17-2012, 09:39 PM   #7
02 Dawg
02 Dawg's Avatar
2002 VUE 3.0L
TOM92SCm and far2grumpy,
Thanks for your help with are 2002 Vue. With your information the heat stop blowing! The plug on the back of the thermostat popped off and the heat would not shut off.
Thanks again,
Heater causes speedometer to stop working championapbt S-Series General 20 08-28-2009 11:13 AM
ABS at every stop!!! tominsky Vue Tech 10 11-05-2005 07:38 PM
Hop hop hop!!! How do I stop? sps SOHC Mods and Performance 23 10-31-2005 12:08 PM
tail/stop/brake lights stop working? (QUICK FIX INSIDE) BLUEION2 Ion General 17 06-21-2004 07:04 PM
Stop Following Me! samats55 Vue General 34 05-06-2004 02:41 PM
