#1 | ||||
![]() Join Date: Jun 2012
Im aware the manual says not to change it, but what do you all recommend and what are your experiences with it? Thanks..
#2 | ||||
The manual does NOT say not to change it. It states, "no maintenance required".
I have 171,431 miles on my SL2 manual transmission and have never changed the transmission fluid and don't plan to. It still shifts the same as when new. Others will give varying opinions. ... 2002 SL2 Manual - new in November, 2001 Sticker: $13,995 As of 03/13/13: 179,571 Miles
#3 | ||||
![]() ![]() ![]() Join Date: Feb 2005
1999 SC1
You don't have to change it, you probably don't need to change it, but you certainly can change it, and some people have reported smoother shifting after changing it.
Your call, it's not likely to make a difference in the longevity of your Saturn. ... SaturnSeries.net owner
#4 | ||||
![]() Join Date: May 2011
Change manual transmission fluid every 100K or so...
Otherwise you risk breaking a valve stem.... Both manual and autos used to be "fill for life", not anymore... Use a Dex III, not a Dex VI.
#5 | |||||
![]() ![]() ![]() Join Date: Apr 2009
and unless the fluid can go for MANY miles/years by default from the factory (think over 10 years and WELL over 100k miles or so), fill for life for any kind of oil/fluid is a dumb statement IMHO. all it means is "hey it'll last for 100k or whatever miles so then you can trade it in" other than that, +1 to using dex III; most board members use Amsol fluid for Allison transmissions, or some other synthetic. ... 97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive & Well 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, prolly needs front driver strut
#6 | ||||
If an automatic transmission on an S-Series was "Fill for Life".. then why do parts stores stock auto trans filters?
That's just not the right information... saying that autos are "Fill for Life"... If memory serves me... it states in the saturn manual that for manual transmssions, a change of the fluid at the first 6,000 miles is suggested and then after that, it should be good. For automatic trans- I believe the interval is every 30,000 miles. Remember that there are not as many moving parts in a manual trans as there are in an automatic. Hence, there is also a different amount of fluid required. The manual trans only requires a little over 3 quarts, while the automatic requires approx. 7 quarts. ... Bryan 94 SL2 215K Miles 97 SW2 246K Miles Garaged 94 SL2 HCE, "Pearl" Never Forget 94 SC1 340,501 Miles Original Engine/Auto Trans 02/97-10/08 Gone 03/12 92 SL1 05 VUE 91 SC
#7 | ||||||
![]() I noticed a change when I went from the factory fill to mobil 1 synthetic ATF on my 5 spd at roughly 110k miles, did not notice a change when I went to Dexron/Mercon (had an axle change in there), and next fill will probably be Transynd ... ...Wait, what, I actually won that eBay auction? Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p And now (7/2010), a Craigslist 1997 SC2 5 spd
#8 | ||||
![]() Join Date: Aug 2009
1996 SL
Back to the original question --
The manual transmission is not as fussy about needing the oil changed as an automatic would be, but I did change mine because it had over 125K on it. I used Castrol Transynd synthetic just because I had a case of it here. Maybe it's my imagination, but I feel like it has been shifting smoother, particularly in the winter cold. Be sure not to overfill it. Doesn't take much . . . . ... -------- Nels Manitowoc WI 1996 SL, 5 Speed manual ╠╬╝
#9 | ||||
Mine is a 93 Sl1, and shifting is a little iffy. So I am considering getting it changed.
#10 | ||||
1999 SC1
It's about the easiest DIY job there is, and a job that I could see many shops gouging on. You remove one bolt (drain plug), let the fluid run out, put it back in, remove the trans dipstick, stick a funnel in the top, and fill it. It's easier than an oil change.
#11 | ||||
![]() Join Date: Aug 2007
Change it. You have nothing to lose.
Use Amsoil ATF and you will not be disappointed, especially in cold weather (if that applies to you) ... 1996 SL2 5MT. 239KMs. Gone, but not forgotten. 2000 SW2 5MT. 133KMs. Gone, but not forgotten.
#12 | ||||
I meant transmission valve body...
#13 | ||||
![]() Join Date: Jun 2007
I'm running Mobil synthetic, on an MP3 trans, it helps cut down some of the gear noise, I wish I had the eco tranny.
... 2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong..
#14 | ||||
![]() ![]() Join Date: Dec 2010
1996 SL1
No such thing as ( Long Life Transmission oil ) if there was they would have
one for Your engine." LOL ... so called Life Long fluids from manufacture,dealers are diceaving and meant to distroy your engine or tranny so You buy another car DONT.! Fall for them. ... " Any man that doesen"t share his knowledge in cars is wrong to do !"
#15 | ||||
...didn't I just say something like that earlier?
#16 | ||||
![]() Join Date: May 2012
1997 SL
Helpful information in here for sure. I checked my fluid at work earlier and realized it was a pint low [according to the dipstick] which would [i'm hoping] explain the notchy shifting, especially the need for more pressure to get in first from a stop *correct me if i'm wrong here*. I'm not sure what kind of fluid my car has now, but i'm planning to top it off with some Dexron III. With no wishes to threadjack,
I have a quick question though. With the variable city climate in New York City [Manhattan specifically, so ad in the occasional stop and go traffic], say, the lowest can be ~5º, highest can be ~100º, what kind of fluid would you guys recommend [and while i'm at it...what weight oil would you recommend? 5w30 is fine to continue using?] ... ♪Nothing can survive the will to stay alive...'Cause if you try, you can do anything!♪
#17 | ||||
![]() Join Date: Aug 2010
+1 to the Castrol Transynd...3,000 miles into my new change and loving it! I'll never use another tranny fluid in my Saturn again...
Plus -- some on here contend that filling an autotragic with Transynd is indeed fill for life. I still plan on changing mine at 30k though.
#18 | |||||
#19 | |||||
#20 | ||||
Yep - I love the shifting in my autotragic now thanks to Transynd (and a new valve body). I'd been considering having a sample analysis done, but don't know where they're done around here. I suppose I could try the heavy truck place where I bought the Transynd from, as I'm sure they must routinely test their truck oils?
| Thread Tools | |
| Display Modes | |
| How to change transmission fluid in VUE with manual transmission | David 93 SL2m | Vue Tech | 12 | 09-10-2012 04:35 PM |
| Manual Transmission Fluid | rgrafton | S-Series Tech | 36 | 08-13-2012 09:26 PM |
| Manual transmission fluid | rgrafton | S-Series General | 9 | 04-25-2012 08:33 AM |
| 98 SW2 Manual Transmission Fluid | SW2 Driver | S-Series General | 8 | 05-25-2007 02:55 PM |
| Manual Transmission fluid | Mr Mike | S-Series General | 13 | 05-08-2004 11:38 PM |
