Old 06-12-2012, 04:18 PM   #1
solarcar_sc1
solarcar_sc1 is on a distinguished road
solarcar_sc1's Avatar
Default PCM question. URGENT!!!!
thank you for reading. I am currently swapping out a 1999 saturn SC1 (sohc) motor for a 1999 saturn SW2 (dohc) motor, the SW2 had 4 plugs going into the PCM while my SC1 only had 3 plugs, however the sohc pcm has 4 slots for 4 plugs, and Im missing one. I was told that i can use the existing sohc harness with the dohc motor. is this true and if so what was the other plug for?
If life is flying by, DOWNSHIFT!!!
1999 SC1.5 DOHC swap, 1998 MP3 tranny swap, cam mod, CAI.
Add to solarcar_sc1's Reputation
Rate the quality of this post and help solarcar_sc1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
solarcar_sc1 is offline   Reply With Quote
Old 06-12-2012, 04:19 PM   #2
solarcar_sc1
Default Re: PCM question. URGENT!!!!
and if I can use the sohc harness, will the vehicle still be able to perform?
thank you.
Old 06-12-2012, 05:55 PM   #3
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Is the SOHC a manual and the DOHC an automatic?
Old 06-12-2012, 06:10 PM   #4
solarcar_sc1
no they are both manual trans. no abs on either. same options
Old 06-12-2012, 09:27 PM   #5
I would pull the DOHC engine harness, cluster and PCM and stick them into your modified SC.
PCM connectors.
J-1 Lt Blue 32 pin
J-2 Lt Blue 24 pin
J-3 Pink 32 pin Auto trans cars only
J-3 Brown 32 pin Manual trans cars only
J-4 Pink 24 pin Auto Trans cars
Manual harness/car has 3 connectors, 2 blue and 1 brown.
Old 06-12-2012, 11:09 PM   #6
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1997 SW2
But the SOHC _WAS_ an automatic right? Before you converted it to manual?
The autotragic computer is built into the same module as the PCM, ABS is a separate module. When I converted a '93 SL2 I had a left over connector and just had to hold the ABS module from attacking my head (don't have to worry about that with 2nd/3rd gens) when I put a '94 SC2 computer in it. I also took the PCM from a '97 SL2 5spd that had ABS, pcm only has 3 connectors and had a separate module for the ABS.
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 06-13-2012, 05:36 AM   #7
solarcar_sc1
The sohc was a manual from the factory. As for the dohc harness. The nimwits at the salvage yard decided on the brilliant idea of cutting the harnes just behind the driver headlight.
Old 06-13-2012, 07:17 AM   #8
What are the connector colors on the harness with the 4 connectors and the same for the 3 connector harness.
Old 06-13-2012, 08:23 AM   #9
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
It's possible that if you look in the donor car, you'll see four harness connectors under the dash ===> donor car experienced a manual swap sometime in the past and the surgeon retained the auto PCM.
Add to madpogue's Reputation
Old 06-13-2012, 09:46 AM   #10
solarcar_sc1
The donor harness had 2 brown 2 blue. The sohc has 2 blue and 1 brown which is the large connector missing the small brown connector. Both are 1999. Im truing to get ahold of the salvage guy to see if he can match up vin numbers.
Old 06-13-2012, 01:55 PM   #11
solarcar_sc1
But of course they didnt answer
Old 06-13-2012, 04:37 PM   #12
Was one of the brown connectors actually pink?
Old 06-13-2012, 10:26 PM   #13
And the donor PCM has four connectors? And, sorry gotta ask, you def. saw a manual shifter in the donor car?
Old 06-13-2012, 11:14 PM   #14
solarcar_sc1
100 percent positive. Its the same car i took the shifter cables out of. Just incase the original fray.
URGENT belt tensioner question?? demoncamber S-Series Tech 2 12-24-2010 02:29 PM
urgent transmission question chingondearmona S-Series Tech 10 09-26-2010 02:30 PM
Urgent question on thermostat! PSDFan S-Series General 29 05-05-2009 10:10 PM
Urgent question about coolant change xybaby S-Series Tech 1 04-26-2009 05:35 PM
Urgent question 01SL1SATURN S-Series General 10 11-02-2008 09:57 AM
