Old 06-12-2012, 03:27 PM   #1
Zosozeppelin
Zosozeppelin is on a distinguished road
Zosozeppelin's Avatar
2006 ION-3 Quad Coupe
Default Checking to see if I put my hose back on right
Today, I changed my air filter for the first time (I feel so accomplished! Yay me!). I've never done anything like this on a car, and I refuse to pay the $60 to let the dealer do it, so I decided it was time I learn (for those of you who don't know, I'm a 20 year old girl who knows nothing about mechanics). The air hose popped off when I removed the cover, and I put it back on, but I was checking to see if I needed to stick the cover in further down the hose. Please excuse my lack of knowledge of the technical names of these parts
By the way, those clips were a pain. Only one popped off easily. I ended up skinning two knuckles and somehow cracked a thumbnail and made myself bleed getting them off
Elizabeth
'06 Level 3 Quad Coupe, spoiled rotten. Just hit 90k miles.
Add to Zosozeppelin's Reputation
Rate the quality of this post and help Zosozeppelin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zosozeppelin is offline   Reply With Quote
Old 06-12-2012, 03:50 PM   #2
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
Default Re: Checking to see if I put my hose back on right
Yeah, but, you're not supposed to break a nail, girl!?
Here's a picture of what we call worm clamps as the little screw thingy needs either a flat blade screwdriver or socket to turn the screw clockwise (tighten) or counterclockwise (loosen), relative to facing the screw head. Your picture looks like the air hose isn't on completely because of the hard plastic tab to the left of the clamp. It appears that the clamp is too tight and needs to be loosened as much as possible (the clamp made larger in diameter) before the tube that fell off can be fitted on better. Once you loosen the worm clamp the tube underneath it will be easier to fit over the plastic tube until the mated ends fit nicely. Take it off to see how one fits over the other and mates with tabs for alignment. Once back one about 1/2 inch or so the clamp can be tightened until the fitting is firm without deforming both plastic tubes.
Perhaps some 'male' aquaintenances(SP?) can show you with their egos in check.
*The CPS is the heart of the entire EFI system. No cps = dead EFI system*
*There's more to a/c than just a few cans of refrigerant*
*There's more to brakes than just replacing parts*
Old 06-12-2012, 04:03 PM   #3
Zosozeppelin
Most of my guy friends are USELESS when it comes to cars, haha. I figured that it wasn't on all the way and that I'd have to unscrew the worm clamp thing to get it on right. Is it safe to start it up and move it into my garage with the hose like that, or should I just do it in the driveway?
And it doesn't bother me that I broke my nail. I was such a nail biter when I was little that I keep them short anyways, and all it did was just crack a little. I'm not afraid of getting hurt and getting my hands dirty!
Elizabeth
Old 06-12-2012, 04:19 PM   #4
The car won't be hurt. You can move the car into the garage to finish it right. All this did when it fell off was expose unfiltered air for the time you didn't notice it and its not good to have it this way if you drive in the city with all the dirt kicked up from traffic. Better to find out now and fix it while you can and channel filtered air into the engine.
Its too bad for the boys that you know that aren't experienced in car maintenance.
Any time you work on the car, try any hand lotion to grease up to your elbows with it. The best ones are the ones that dry out so tools and parts don't slide off your hands or fingers. Wait a few minutes for lotion to dry up or place your hands on a dirty part of the car to pick up fine dirt - this now makes your hands gritty and wipes off enough to allow instant gripping. The lotion seals the pores and allows washing off the real greasy dirt later since it doesn't get into the pores. There's a special hand cream that auto stores sell just for this purpose to seal your hands from grease and oil and makes wash up fast leaving almost no trace of grease. A finger scrub brush does the rest. Borax powder is one brand, Orange ******(?) is another degreaser with grit to help clean off greasy hands. Then follow up with hand lotion to keep the skin soft from drying out.
Old 06-12-2012, 04:51 PM   #5
Zosozeppelin
Thanks for your help, fdryer! And thanks for the lotion tip, I'll do that next time I decide to be bold and venture under the hood! (Probably for when I buy my K&N air filter that I wanted to install instead of the STP one I got). I got it on nice and snug. It really is a lot easier than the owner's manual makes it out to be, I was a little intimidated at first.
And I think it's time I got that engine bay cleaned out... lol.
Elizabeth
Old 06-12-2012, 08:54 PM   #6
golftango
golftango is on a distinguished road
golftango's Avatar
2009 AURA XE
Fdryer is spot on, once again. Glad to see someone who's not afraid to get their hands dirty and learn about general car maintance. Another tip, go to Harbor Freight and pick up a huge box of Nitrlie gloves. Comes in handy, no pun intended, to keeping the hands clean.
'09 Saturn Aura XE
Add to golftango's Reputation
Rate the quality of this post and help golftango reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
golftango is online now   Reply With Quote
Old 06-13-2012, 12:16 AM   #7
Zosozeppelin
I'll have to look into that. Since I'm broke and in college, anything I can do myself to save money I'll do. It seems pretty senseless to me to pay the dealer that much money when I spent $8 to change it myself.
Elizabeth
checking ecm bobcats S-Series Tech 3 08-17-2011 03:21 PM
Code P0410 - Hose replacement from secondary pump to back of engine HomeBase S-Series Tech 7 04-24-2009 05:12 PM
Checking oil daoyee S-Series Tech 10 09-19-2006 10:45 PM
97 SL1Replacing short crimped hose from res to hose assy? Chris0381 S-Series General 1 05-28-2005 01:06 PM
