Astra General Photos
by dzajic
Astra - Member Photos
229 photos
77 comments
by fotc13
229 photos
77 comments
by Charlie
2008 - Media Photos
43 photos
8 comments
by Charlie
2008 - Astra Road Test
86 photos
7 comments
Old 06-12-2012, 02:29 PM   #1
phatfire6
phatfire6 is on a distinguished road
phatfire6's Avatar
Default Upgraded brakes
Just tossed on some 4 pot calipers today. They sure do stop the car in a jiffy. Didn't take too long to install. Need to head out and bed the pads in. Took this pic with my cellphone:
Add to phatfire6's Reputation
Rate the quality of this post and help phatfire6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phatfire6 is offline   Reply With Quote
Old 06-12-2012, 04:18 PM   #2
bellman246
bellman246 is on a distinguished road
2008 Astra XR
Default Re: Upgraded brakes
Thoes look sick! How much were they?
- 2008 Saturn Astra XR 5dr Twilight Blue
- Manual
- 8000k HID, LED Corner Lights, LED Plate Light, Yellow Fog lights
- Shark Fin
- MTX sound System with 10 inch sub
- D5103
- Pro Lines
Add to bellman246's Reputation
Rate the quality of this post and help bellman246 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bellman246 is offline   Reply With Quote
Old 06-12-2012, 07:00 PM   #3
bellman246
2008 Astra XR
are those lug covers BTW?
- Manual
- Shark Fin
- D5103
- Pro Lines
Old 06-12-2012, 07:11 PM   #4
phatfire6
phatfire6's Avatar
It is prohibitively expensive. You can buy the complete kit for roughly $2400. I bought them in separate pieces. Got the calipers and mounting brackets from the UK, and had locally manufactured rotors made at Coleman Racing. Besides it being significantly cheaper this way, the wallet shock was much less by spreading the cost out over a period of time so I could save for it.
These things surprised the crap out of me. I normally drive a Nissan Xterra, and the brake pedal requires a heavy foot for normal braking. Out on the first trip after the install, while braking while coming off of the highway, all of the stuff in my car went flying towards the front. This is going to take some time to get used to. It won't be fun to be a passenger in my car during this small learning period.
Old 06-12-2012, 07:12 PM   #5
phatfire6
phatfire6's Avatar
Yes, those are lug bolt covers
Old 06-12-2012, 11:17 PM   #6
jrll1981
jrll1981 is on a distinguished road
Those brakes are really cool looking, and work beautifully from what you described. Track ready?
Add to jrll1981's Reputation
Rate the quality of this post and help jrll1981 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jrll1981 is offline   Reply With Quote
Old 06-17-2012, 02:50 PM   #7
nicolas_p
nicolas_p is on a distinguished road
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
I got your new bumper sticker
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Eibach Sportline, Whiteline BHR75Z swaybar and EBC Rotors
CD30 Mp3, Insignia jets, vxR surround, sharkfin antenna, Spoiler, Tint
Add to nicolas_p's Reputation
Rate the quality of this post and help nicolas_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nicolas_p is offline   Reply With Quote
Old 06-18-2012, 06:37 AM   #8
blackastra
blackastra is on a distinguished road
blackastra's Avatar
2008 Astra XR
2008 AURA XR
Originally Posted by jrll1981 View Post
Track ready?
Lol...Saturn Astra on the track. Good one.
Add to blackastra's Reputation
Rate the quality of this post and help blackastra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackastra is offline   Reply With Quote
Old 01-14-2013, 12:47 AM   #9
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
Just to revive an old thread, was size are the rotors. Because I want to get bigger brakes on my car but i am limited to 17" overall size because I have my winter rims?
Old 01-15-2013, 04:17 PM   #10
phatfire6
phatfire6's Avatar
You could have just sent me a text, Nick
Follow this link - it will open up a PDF file of a rotor spec sheet.
http://www.colemanracing.com/Assets/file/Hat_Rotor.pdf
I using the solid mount rotor, here are the dimensions in mm.
A= 28.0
B= 343.0 <--- This is the dimension you are looking for.
C= 198.0
D= 237.5
E= 215.9
F= 6.4
F= 12 holes
G= 6.5
H= N/A
I= N/A
Coleman can make you rotors at a significant savings. They can also make a custom bell for you as well. Combine the rotor/bell with a 13.5" compatible caliper, and you have yourself a deal.
As for the 17" part - they are designed to run in 18" wheels. Can they fit in 17" wheels? I'm pretty sure that it wont. The caliper and rotor are such an easy install, it shouldn't take you more than an hour to swap out to the stock calipers come winter time. I installed mine in about thirty minutes.
Old 01-15-2013, 06:30 PM   #11
romanster
romanster is on a distinguished road
romanster's Avatar
Can coleman do cross drilled rotors or do they prefer slotted? Did you give them dimensions from the AP bells to duplicate, or did they have a donor bell to use?
Another option on the cheaper side would be Cobalt SS Turbo front Brembo's, the Saab 9-3 guys are big on this retrofit since the refurb'd Brembo calipers can be found pretty cheap. They use 314mm rotors on the Saabs with this setup, it may be the same for our Astras, or we may keep the stock rotor size. All this with parts readily available in the States and Canada. We may need spacers to push the wheel farther out since the calipers are bigger, the cobalt and saab guys do this depending on their wheel clearances. It would all be trial and error at first, since I haven't seen this swap on an Astra before. They use the setup on 17" wheels too.
The oem Astra VXR/OPC front brakes are 322mm and are a direct swap onto all Astra H models. They also mount 345mm brakes from the Vectra VXR with some modification to the caliper carriers. I think some Saabs also come with 345mm front brakes, so that could be another option.
Of course if you want to ball out, the K-Sport kit for the Astra VXR is a 356mm rotor with 8-piston caliper and 18" min wheel size.
And for the truly rich, there is a guy in the UK VXR forum who can put together kits with Audi RS6/R8 390mm rotors for the Astra, and they just barely clear 19" wheels:
Astra XR3 white
|Vauxhall VXR honeycomb V grille
|New-style griffin emblems, GTC badge
|Insignia VXR 18" replica wheels
|4300K HID, LED bulbs all around
|Blue interior LED conversion, VXMMI + GID
Add to romanster's Reputation
Rate the quality of this post and help romanster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
romanster is offline   Reply With Quote
Upgraded my radio luke.111 Astra General 31 03-26-2012 12:05 AM
Upgraded sway bar? Ritz Vue Mods 55 08-25-2009 11:05 AM
Anyone upgraded the brakes? XR524 Aura General 6 06-20-2009 08:25 PM
Can the 07 DIC be upgraded to 08? SHNYROQ Aura General 4 07-22-2008 10:04 AM
I upgraded... Son93SL2 S-Series General 4 12-11-2004 10:48 AM
