Old 06-09-2012, 12:59 PM   #1
SC1Murder
SC1Murder is on a distinguished road
Default SC1 Tail Light conversion to LED
I was wondering if anyone has converted their tail lights over to LED. lemme know how you did it and where u got the components for it.
Add to SC1Murder's Reputation
Rate the quality of this post and help SC1Murder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC1Murder is offline   Reply With Quote
Old 06-09-2012, 01:04 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: SC1 Tail Light conversion to LED
superbrightleds.com
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 06-10-2012, 01:20 PM   #3
SC1Murder
hmmmm this isnt really what i was talking about but it works sorta. i was wondering if there is a way to just completely rearange the lights
Old 06-10-2012, 01:30 PM   #4
Well, ask what you actually want then Converting to LED's is as simple as replacing the bulbs.
Moving the bulb locations somewhere else requires fab work, though you might be able to use tail lights from a '97-'99 SC, if they have the light setup you want.
Old 06-12-2012, 11:03 PM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC1
As is so often the case, "if you have to ask if you can do something, you probably can't" (this generally gets applied to engine swap questions, but the same goes for anything that requires custom fabrication.)
Can someone do it? Yes. Someone can put a man on the moon. Question is, can you do it? We can't really answer that.
Tail light light Bulb replacement on 1998 SL1 PKTLEUNG S-Series Tech 3 02-14-2008 03:03 PM
2000 SL tail light/back up light problem pointyskull S-Series Tech 11 09-19-2007 04:50 PM
Tail Light Works/ Brake Light Won't MN97SL2 S-Series General 4 11-27-2006 10:41 PM
2000 LS Brake Light/Tail Light Problem golfnut44 L-Series Tech 4 11-25-2006 05:41 PM
SC2 light conversion kit available? gfxdave99 Mods and Performance 2 05-11-2001 08:50 AM
