Old 06-02-2012, 05:36 PM   #1
WAB
WAB is on a distinguished road
WAB's Avatar
1996 SC1
Default 01 SW2 53k miles $2k - but wait, there's more
Saw this on C-list in Jacksonville at a used car dealer. I've been looking for a wagon, and this one for $2k seems like a great deal. My current 2000 SC1 is about to turn 200k and its just really small. The drivers seatbelt in the 3rd gen 3door is just plain hellish to wear.
Drove it 120 miles back to Savannah today. Changed the oil and trans fluid and noticed that the lower block has been welded! Its not leaking fluids now. It does not appear that the motor has been pulled from looking at the bolt heads.
Check it out.
I pulled the air intake tube off.
See anything out of place or wierd? My other 3 Saturns were all SOHC's.
Add to WAB's Reputation
Rate the quality of this post and help WAB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WAB is offline   Reply With Quote
Old 06-02-2012, 05:38 PM   #2
WAB
WAB's Avatar
1996 SC1
Default Re: 01 SW2 53k miles $2k - but wait, there's more
Old 06-02-2012, 06:49 PM   #3
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
At one time it was leaking water there. pull back and get a shot that includes the radiator support. You can see the signs of the leakage.
Old 06-02-2012, 08:24 PM   #4
WAB
WAB's Avatar
1996 SC1
Here ya go.
It seems to run smooth. It does have a granular type dried substance splattered around the motor (like dried salt water). It this old antifreeze that sprayed out when it blew?
Should I worry or take any proactive measures?
Is this common on the DOHC motors?
Thanks for the help!
Old 06-02-2012, 09:01 PM   #5
amazinghl
amazinghl is on a distinguished road
If there is no oil in coolant, no coolant in oil, and no leaks now, I wouldn't worry about it too much.
89 CSX 99.7 mph trap and climbing
85 GLH 102 mph trap
94 855
Add to amazinghl's Reputation
Old 06-02-2012, 09:02 PM   #6
TXSaturn02
TXSaturn02 will become famous soon enoughTXSaturn02 will become famous soon enough
TXSaturn02's Avatar
Fresh paint under the hood in just that one area would make me nervous too.
Sticker: $13,995
As of 03/13/13: 179,571 Miles
Old 06-02-2012, 09:18 PM   #7
Spray it down with Simple Green and wash it all down. Be careful what gets squirted with water. Should be just fine. It is highly likely it is crash damage or a fluke failure. I would not worry about it other than cleaning it all up and see what develops. It runs, it is a wagon, and it is a manual.
Old 06-02-2012, 09:31 PM   #8
WAB
WAB's Avatar
1996 SC1
Originally Posted by OldNuc View Post
It is highly likely it is crash damage or a fluke failure. It runs, it is a wagon, and it is a manual.
I hope it lasts me many years!
It does an impact hole in the front bumper, the oil pan is scuffed (pavement), and the rear bumper is damaged on both sides.
The slimy used car dealer said they had to replace the rad fan. I think they actually just ran power to it if the key is on.....
Old 06-02-2012, 09:50 PM   #9
If the fan comes on when the key it turned to ON the ECTS circuit could well be fubar. With a voltmeter check between the 2 wires fro 5vDC, key on. Replace ECTS. You will need a scanner to be able to read these sensors and it is worth the effort to get one.
Old 06-02-2012, 11:19 PM   #10
PurdueGuy
PurdueGuy's Avatar
1999 SC1
That SC1 would look soooo much better lowered.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 06-03-2012, 12:37 AM   #11
dynonacht
dynonacht is on a distinguished road
dynonacht's Avatar
wat a clean sc
Add to dynonacht's Reputation
Rate the quality of this post and help dynonacht reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dynonacht is offline   Reply With Quote
Old 06-04-2012, 10:02 AM   #12
WAB
WAB's Avatar
1996 SC1
It still is weeping a tiny bit of fluid from what must be a tiny pin hole in the welded area. Some came out while parked overnight. When the motor is hot, it must steam off before it is noticeable.
Plan to degrease/clean the area, wirebrush the area, and use what to finish sealing it? Devcon? JBweld? 3m 5200?
Compression is good, all 4 cyl are within 5psi of 185.
Old 06-04-2012, 10:24 AM   #13
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
"Fluid" meaning coolant? Try a cold pressure test - test cap on the reservoir, pump it up with air to 20 psi. Might get that pinhole leak to show itself while cold.
Add to madpogue's Reputation
madpogue is online now   Reply With Quote
Old 06-04-2012, 10:39 AM   #14
There are 2 things that will work. POR-15 Por-Patch or BARS Leaks golden seal powder or tablets. Use a single tablet. Do not use any other stop leak. This stuff or the tablets in the same type of package. Use only a single tablet. http://www.saturnfans.com/photos/sho...p?photo=50350# Por-Patch, http://www.por15.com/PORPATCH/productinfo/PPB/
Do not pressurize system over 12-13psi or you will spring the radiator end seals.
Hot glycol will break the bond with epoxy etc. In other words there is very little that will stay stuck.
The Wait is Almost Over AstraBoy Astra General 5 08-19-2008 03:14 AM
'05 Vue RL or wait for '06 FrankBullitt Vue General 5 06-30-2005 09:05 AM
Buy now...or wait? tmanson78 Vue General 9 07-01-2004 03:33 PM
Like New 16" Chrome-Clad L-Series Wheels (4,500 miles) with tires (250 miles) UH2L Old Classifieds 6 07-07-2003 02:34 PM
Buy Now or Wait? Motley00 General Saturn Discussion 3 04-30-2000 07:06 PM
