#1 | ||||
![]() Join Date: Jun 2012
Hi
I'm new to this forum and hope to get some help. 94 sl-1 4 door with manual windows. driver's window won't roll up all the way last 1/2". I guess the regulator needs work or replacement. I have removed all torq screws for the door skin to access the regualtor but the outside door handle must come off ;how ? I figure maybe some interior door panel fasteners must be removed and therefore removed 2 in the indented plastic cup shaped handle area and the one near the inner door latch ; door panel wants to come off but window crank handle must come off ,how is this done ? everything easy so far but don't know about the door handle and the window crank handle removal. Any info appreciated. Thanks in advance
#2 | ||||
I had a similar problem with mine. I removed the outer door skin using this method
http://www.differentracing.com/tech_...uterpanel.html Then I cleaned the track using silicon spray lube with a rag, then relubed with silicon grease. This was on a "97" yours may be similar, others should have more info. ... 1997 SL1 5 speed manual 343,000 mi.+
| Thread Tools | |
| Display Modes | |
| Manual window problem | gearhead | S-Series Tech | 18 | 07-13-2012 10:10 AM |
| 94 sl-1,manual window problem | 1tealsaturn | S-Series General | 1 | 06-03-2012 12:23 AM |
| 94 sl-1 ,manual window problem | 1tealsaturn | Support Forum for Canadian Saturn Owners | 0 | 06-02-2012 01:00 PM |
| 92 sl1 manual window?!?!?!?!? | 9tyler2 | S-Series Tech | 3 | 07-01-2010 04:07 PM |
| 96 SL1 Manual Window Problem | wlipford | S-Series General | 6 | 01-10-2005 03:52 PM |
