Old 06-02-2012, 01:59 PM   #1
1tealsaturn
1tealsaturn is on a distinguished road
Default 94 sl-1,manual window problem
Hi
I'm new to this forum and hope to get some help. 94 sl-1 4 door with manual windows. driver's window won't roll up all the way last 1/2". I guess the regulator needs work or replacement. I have removed all torq screws for the door skin to access the regualtor but the outside door handle must come off ;how ? I figure maybe some interior door panel fasteners must be removed and therefore removed 2 in the indented plastic cup shaped handle area and the one near the inner door latch ; door panel wants to come off but window crank handle must come off ,how is this done ? everything easy so far but don't know about the door handle and the window crank handle removal. Any info appreciated. Thanks in advance
Add to 1tealsaturn's Reputation
Rate the quality of this post and help 1tealsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1tealsaturn is offline   Reply With Quote
Old 06-03-2012, 12:23 AM   #2
Signmaster
Signmaster is just really niceSignmaster is just really niceSignmaster is just really niceSignmaster is just really nice
Default Re: 94 sl-1,manual window problem
From Lowsaturn's website....
http://www.differentracing.com/tech_...uterpanel.html
As for the crank handle there is a clip that goes into a slot in the handle. You can use a curved pick tool or slip a thin shirt/rag against the open side and pop it off. If you push in on the door panel some and move the crank you will see the clip and it will start making sense.
Manual window problem gearhead S-Series Tech 18 07-13-2012 10:10 AM
94 sl-1 ,manual window problem 1tealsaturn Support Forum for Canadian Saturn Owners 0 06-02-2012 01:00 PM
Manual Window on 98 SL stormnorm S-Series General 3 01-17-2012 03:32 PM
manual window angeltrash Vue Mods 2 04-03-2007 10:34 PM
96 SL1 Manual Window Problem wlipford S-Series General 6 01-10-2005 03:52 PM
