#1 | ||||
![]() Join Date: Jun 2012
My 2007 GL died on me the other day and we thought it was my alternator and my husband removed it but we couldn't find a place around here to check and after I called the closest GMC dealership which is about 150k away I was told due to my GL only having 55k miles on it, that it couldn't be my alternator and I needed to ck my battery. And sure enough the battery was no good.
Okay now my husband has put the alternator back in but has to 2 cords at the top that plug in to something but we can't a find place for them to plug into. This is a # that was on one of them PA6GB20 GF10 One is skinny and black and the other larger and purple.
#2 | |||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
I don't see any extra wires with mentioned colors. However, vehicle diagrams can have errors. ![]() I know nothing about GL - perhaps we'll get lucky - and someone owning one can offer useful advice. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#3 | ||||
Thanks.. I'm wondering if maybe these are for when you have to hook your car up and have it checked when the ck engine light is on. All the other cords that plug into each other are marked with a red mark and you can tell where they go together. These to cords have nothing on them. And our Service manual was no help..
#4 | |||||
Many folks very much smarter than I could recognize the errant wires. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#5 | ||||
The cords are not really long enough to go any where but right infront of the black plastic cover that goes over the motor.
#6 | ||||
I'm baffled ... they look important ... but does the Vue run with the connectors "blowing in the breeze"?
As previously stated - best hope is for another GL owner/operator to pitch in. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#7 | ||||
My GL will start and run without these cords connected to anything but my check engine light, battery light, & incline light is still on. I've also notice that my hybrid gauge is not moving like it should. There was a recall on the hybrid batteries and I had them replaced this past October.
#8 | |||||
I suggest you send an email address by PM and I'll send the extracts needed to remove the starter-generator. There are too many to post. Perhaps the instructions will remind your worker-bee of something he had to disconnect to get at the SG. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on. Last edited by far2grumpy; 06-03-2012 at 11:59 AM..
#9 | |||||
Both are supposed to be connected to the Starter-Generator. See thumbnails. Two other connectors in same section are connected to the Starter Generator Control Module. Are we absolutely certain the starter generator has been reconnected? ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#10 | ||||
okay when you take about the starter generator are you referring to the alternator? Because the alternator had 3 plugs on it and they are plugged back in. They are matched up due to the red marks that have been put on the black cords. When we plug them all back in they matched up perfectly. These 2 cords have no paint on them like the ones that connect to the alternator. He has taken it apart twice and can't find where they go to. my car starts and runs but the warning lights are still on.
#11 | |||||
I actually thought the truck had a combi starter-generator to get engine cranked and to charge three batteries to keep systems powered when the engine was not operating. If your engine has a standard alternator - in addition to the SG - I'm of no help to you because I can't find documentation to sort that connection out. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#12 | |||||
![]() Join Date: Nov 2004
2007 VUE Green Line
2008 Astra XE
... 2005 L300 (traded) 2007 VUE Greenline 2008 Astra XE
| Thread Tools | |
| Display Modes | |
| Better for Snow: SL2 with Cords or 4wd? | TIMSPEED | S-Series General | 22 | 08-22-2010 01:38 PM |
| Hood release cable crimped, hood stuck in a released state | Cards | Ion Tech | 3 | 01-06-2009 05:05 PM |
| DIY Article: Hydraulic Hood Struts - Replaces Hood Prop Rod | Robman | L-Series Tech | 4 | 11-09-2008 01:50 PM |
| Hood was smashed.. need new hood.. | spork | L-Series General | 10 | 02-28-2004 11:20 PM |
| FS: first gen sc2 hood... perfect for subie hood scoop conversion! | BobDobbs | Old Classifieds | 4 | 04-28-2002 09:54 PM |
