Old 05-31-2012, 12:50 AM   #1
justanotherjpr
justanotherjpr is on a distinguished road
Default 2000 SL1 wheel bearing
Hi everyone. I just bought a 2000 SL1 with 131,000 miles. When driving straight and above ~35mph there is a distinct loud noise - it almost sounds like the car has a fart cannon muffler. When I turn right at speed, it gets worse. If I turn left at speed, it's silent. If I turn even slightly left to move across a lane on the highway it is silent.
This sounds to me like the front wheel bearing/hub. I am planning to purchase the hub repair kit from RockAuto. Does anyone know if the hub repair kit at RA comes with the spindle nut? Any reason to suspect something else? I will be replacing the front rotors/pads at the same time due to warped rotors.
After reading about all the diff pin stuff, I am concerned this could be the problem - luckily the pick n pull over here sells transmissions for $55.
Add to justanotherjpr's Reputation
Rate the quality of this post and help justanotherjpr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
justanotherjpr is offline   Reply With Quote
Old 05-31-2012, 06:53 AM   #2
dbsanfte
dbsanfte is on a distinguished road
1999 SW2
Default Re: 2000 SL1 wheel bearing
Depends on which kit you get. The Moog kit doesn't come with a new nut. But there's another kit (Timkin?) which does. In any case the nut and washer are sold separately on there for $3 and change.
Add to dbsanfte's Reputation
Rate the quality of this post and help dbsanfte reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbsanfte is offline   Reply With Quote
2000 Saturn SL - Front Wheel Bearing Replacement mostapasta S-Series Tech 23 04-22-2013 08:51 PM
FYI..Getting Wheel Bearing Hub out ... WTF! mikenews Vue General 7 01-13-2012 09:37 PM
Wheel bearing? 01SL1SATURN S-Series Tech 4 12-07-2010 12:07 PM
Wheel bearing noise that isn't the wheel bearing? shelby987 Vue Tech 0 06-23-2010 10:16 PM
2000 SL1 rear wheel bearing honda72.1@juno. S-Series General 1 09-27-2008 10:21 AM
