#1 | ||||
![]() Join Date: Feb 2012
2001 L-Series 2.2L Wagon
I recently changed the fuel pump on my 2001 LW200 and now I keep getting the code that says my fuel cap is not tight. I realize that it is most likely that I left something loose when I did the fuel pump, but is it possible the cap is bad? If so, is there a way I can check it?
Other thoughts or places to start before lowering the tank?
#2 | ||||
I am getting the same thing! I am going to reset my code this week to see if it was the gas cap. If it comes back on my next step is going to be to snag a gas cap from the junkyard and hope it stops throwing the code. If not it may be time to pull the tank again... I keep smelling gas too but not constantly so I'm curious if it is my car. Do you smell gas fumes when driving?
#3 | ||||
I haven't smelled any fuel.
#4 | ||||
![]() Join Date: May 2009
2000 L-Series 3.0L Sedan
It sounds like there is not the proper air lock with the venting. I just had a piece of vent pipe in the back replaced because it had rusted through. Something is letting air in and fumes out.
| Thread Tools | |
| Display Modes | |
| I don't have a fuel pressure gauge, is there a way to check problem fuel pump without | dddaaa | S-Series Tech | 6 | 08-06-2011 02:09 PM |
| Fuel Pump 2011: PT3 - Bosch Fuel Sending Unit Part Number? | x-angel | S-Series Tech | 4 | 03-23-2011 11:34 AM |
| Fuel Pump 2011: PT2 - No sender = cut out? And P0410 Code | x-angel | S-Series Tech | 4 | 03-15-2011 05:44 PM |
| Fuel Pump needed changing at 50k | kgoward | L-Series General | 13 | 05-05-2006 04:32 PM |
| fuel pump, code 26 | BRYAN | S-Series Tech | 1 | 10-25-2000 10:35 PM |
