#1 | ||||
![]() Join Date: Jul 2010
On the way back home the trans started to act up. Either from 2-3 or 3-4 the engine would quickly jump up in RPM and then engage the next gear. Does this sound like a bad solenoid or it's something more serious? Makes me wish I changed all the solenoids when I had access to the trans.
![]() ... Stock (for now) 2000 Saturn LS2
#2 | ||||
![]() Join Date: Feb 2010
Sounds typical for a 12 year old vehicle. I would just keep driving it until it totally craps out, then get a new car.
#3 | ||||
That bad?
#4 | ||||
![]() Join Date: Jan 2011
2000 L-Series 3.0L Sedan
Try some lucas trans fix, the stuff actually does some good. Also, maybe try changing the fluid/filter, although you may want to check for codes and bring it to a shop. I am sure you can save it, and if it is cheap it obviously would be worth it. I am not very familiar with our transmission though, so see if you pull a code.
... Proud owner of 2000 Saturn LS2 premium package; HELP ME KEEP IT ALIVE!! @105k
#5 | ||||
When I got this car the trans was already very problematic. So I change the fluid in it once a year, along with the filter. Didn't put Lucas oil this year, guess I'll end up getting a bottle.
The transmission which is a 4T45E is commonly used in a lot of GM cars. The way I see it I could go about this 3 different ways. Given of course I'm going to use the Lucas first and drive it until the trans explodes. #1 Get a junk yard trans. Local junk yards have them for $200 - $350 depending how far I'm willing to drive for one. #2 Get a junk yard trans from a much newer GM car. I think they kept sticking these trans all the way till 2009 model GM cars? I'm not sure if everything will hook up fine electrically. #3 Rebuild the trans. They sell rebuild kits though I've never done it. Certainly don't feel like paying some shop $2k to do it. ... Stock (for now) 2000 Saturn LS2
#6 | ||||
Is it possible that this problem is a bad 2-3 solenoid in the trans? There was a massive vacuum leak that just happened today and I fixed it, but didn't solve the trans problem.
Also, I may end up replacing the trans, so is it possible for me to get a newer trans from a junked 2009 Grand AM GT or G6? At least from a Vue? BTW, the Lucas oil did nothing. ... Stock (for now) 2000 Saturn LS2
| Thread Tools | |
| Display Modes | |
| Started disassembly of 97 sl2m today | vtsl2 | S-Series General | 0 | 04-08-2012 07:46 PM |
| Loud squeeking,burnt rubber smell when I started my car today. | iluvtheflush | L-Series Tech | 5 | 12-10-2011 08:58 PM |
| Battery light started flashing today | jfcadena | S-Series Tech | 3 | 04-09-2011 06:24 PM |
| Started Rebuilt Saturn Today | jdcart | S-Series Tech | 5 | 11-18-2006 08:09 PM |
| Well, today started out alright... | white95SL1 | S-Series Tech | 39 | 08-19-2006 01:21 AM |
