Old 05-30-2012, 04:04 PM   #1
trumsey07
trumsey07 is on a distinguished road
Default fuel issue please help
my truck is currenly down and me and my wifes only other vehicle is a 2005 saturn vue 2.2lt 5sp, well the vue is starting to act up it idles fine but as soon as u start to get the rpms up the motor starts to cut out like its not getting fuel. the rpms dont jump so spark plugs are fine. its bogging out evry time u drive it. the check engine light came on so we had it read and no codes found,so i figured it was bad gas or fuel filter got a filter and went to find it no where to be found i was just wondering if any one had this problem before thanks
Add to trumsey07's Reputation
Rate the quality of this post and help trumsey07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trumsey07 is offline   Reply With Quote
Old 05-30-2012, 05:04 PM   #2
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Default Re: fuel issue please help
How many miles are on the little guy?
Fuel filter... inside the tank...
If you turn on the A/C, does it act any different at idle?
Check the picture in post #9 of the thread below to make sure of which light is on...
http://www.saturnfans.com/forums/sho....php?t=180894#
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 05-30-2012, 05:27 PM   #3
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
If it were mine I'd trace the harness for pre-cat O2 sensor back to first connector and unplug.
Its OK to drive like this for awhile as the ECM will revert to default fuel program.
If the stumble remains the next step is check fuel pressure.
If stumble goes away - replace the O2 sensor.
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
Old 05-30-2012, 07:09 PM   #4
trumsey07
ok so i checked out the link and the light that comes on is the service engine soon, the vue has just over 100,000 miles.
Old 05-30-2012, 08:33 PM   #5
trumsey07
so i unplugged the o2 sensor and gave it a shot no real difference and in repley to the ac i tured the motor on it idled fine but as soon as i turned the ac on the rpms acted up and the motor shook badly
Old 05-30-2012, 09:42 PM   #6
far2grumpy
far2grumpy's Avatar
Missing under load could be so many things.
You could pull at least one plug to check condition.
See attachment for a list of possible suspects.
Old 06-04-2012, 10:15 AM   #7
surfstar
surfstar is on a distinguished road
I'd be leaning towards ICM and/or coil pack. Should be a CEL stored, just gotta find a reader that can read it!
2005 Dragonfly Green 2.2L MTX Vue
Add to surfstar's Reputation
Rate the quality of this post and help surfstar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
surfstar is offline   Reply With Quote
Fuel delivery issue dwarffortress S-Series Tech 17 04-07-2012 03:45 AM
fuel pump issue christopher55 L-Series Tech 7 02-17-2011 09:51 AM
98 sl2 fuel issue? 76oldsguy S-Series Tech 26 01-03-2011 02:47 PM
Is This a Known Issue With The Fuel Level? zallen777 L-Series General 16 05-05-2005 11:54 AM
Fuel Pump Issue SoUp S-Series Tech 4 12-31-2004 11:17 AM
