Old 05-30-2012, 02:22 PM   #1
simkid5614
simkid5614 is on a distinguished road
simkid5614's Avatar
Default Sunroof inoperable after heavy rain.
power windows Work and the SUN fuse isnt blown. What wires on the switch can i jumper to see if the motor has failed? I noticed small amounts of water sitting on my shift tower. I went to use the switch and no sounds.. My sunroof worked two days ago. And i didn't have a drainage issue before this. AFAIK tracks are fine and it drains properly.
Help.!
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong..
Add to simkid5614's Reputation
Rate the quality of this post and help simkid5614 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
simkid5614 is offline   Reply With Quote
Old 05-30-2012, 03:02 PM   #2
simkid5614
simkid5614's Avatar
Default Re: Sunroof inoperable after heavy rain.
Strange but problem fixed itself.
Old 05-30-2012, 03:07 PM   #3
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1997 SW2
You didn't have a problem before the problem started? How interesting!
Sounds like somewhere, probably towards the front, it's not sealing or draining properly anymore. If you pull the map lights out you can access the motor (or even replace it without lowering or damaging the headliner), 12v one way opens the roof 12v the other way close's it (dunno which color does which). Hopefully it's not collecting water to drain on your head when you remove the map lights
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 05-30-2012, 03:13 PM   #4
simkid5614
simkid5614's Avatar
Pulled the map lights and there was no water. I checked for power and It's live. I purposely Blew out a fuse, replaced the fuse and Voila. It works. Idk how. I got it opened, Checked the drain tubes 3/4 drained properly the RR is a bit slow.. but I won't complain too much it still drained. When I first bought it back in 2011, I modified the front tubes, I'd cleaned them, then chopped the tips of the cones off to allow better drainage. I poured four bottles of water in the tracks and drains properly. So i figured Whatever, Cleaned out the grease i did last year and re-greased it. But It works so IDK.
Sunroof now inoperable, help requested niko521 S-Series General 9 05-27-2012 03:08 AM
Heavy Rain, Bad Liner, HELP PLEASE Sikh S-Series Tech 8 11-03-2009 07:52 AM
Sunroof wont go closed....calling for rain tonight! :0 browntown3 S-Series Tech 3 03-03-2008 09:19 AM
window down + heavy rain = horn sounding? WTF!?!?! fetchitfido S-Series Tech 5 08-07-2007 02:09 AM
side mirrors problem in heavy rain jds Vue General 6 09-02-2003 01:29 PM
