Old 05-20-2012, 09:25 AM   #1
wobbles1
wobbles1 is on a distinguished road
1998 SL
Question Check engine light need help
Hello, i need some help, i own a 98 saturn sl
i took my car to be inspected, got these errors :
P0107 Map sensor low input - since replaced
P0117 ETCS - its fubar i tried replacing it and it broke off flush my mechanic doesnt wanna drill it out.
P0122 TPS - since replaced
P0301 Misfire 1 - since replaced plug
P0327 Knock sensor - havent checked cuz it detected misfire
P0341, P0340 Cam position sensor ''A'' circuit - i dont have a clue what this means, i know the 98's used cylinder 4 as the cam sensor, so what is wrong?
i had autozone read codes after i replaced those mentioned above, now i only have P0117, P0341, P0340.
any ideas what i can do to fix this, mainly the cam error. could the ETCS be causing the cam error? any help would be greatly appreciated also i tried having ignition module tested at autozone apparently they dont have the connection for mine, figures. thanks
Add to wobbles1's Reputation
Rate the quality of this post and help wobbles1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wobbles1 is offline   Reply With Quote
Old 05-20-2012, 11:20 AM   #2
Default Re: Check engine light need help
You're chasing your tail until you resolve the ECTS issue. No need to drill it. When it broke off, did it leave the hollow end of the sensor in the head? If so, just find an easy-out time screw extractor that will fit in the hole. Tap it INWARD toward the head, gently. Each time you tap it, it should turn counterclockwise a bit, indicating that it's biting into the sensor body. Once you see it turn 1/8-1/4 turn as you tap it in, start gently turning counterclockwise on it. Use a vise-grip or small open-end wrench on the square flats of the easy-out. Soon you'll start to feel the sensor backing out. Be patient and keep turning. When it gets close to coming out, have the replacement sensor at the ready so you can put it in as soon as the old one comes out. Tighten the new one to 71 INCH-pounds (that's <7 ft-lb). You need an inch-pound range torque wrench for this. Remember, you're not fastening two parts with this; it's just a "plug", and you do NOT bottom out the threads.
Add to madpogue's Reputation
Old 06-02-2012, 09:31 AM   #3
wobbles1
1998 SL
it broke off inside, so that the threads are inside the head. the sensor is recessed just a tad inside the hole. do you know the diameter of the extractor i would need?
Old 06-02-2012, 10:36 AM   #4
Buy the set. 3/16 or 1/4 will work but you have to get in there and dig out some of the insulation so the extractor has a clear shot to dig into the brass.
Steady Check Engine Light (Low Engine Power?) labelcd6 Vue General 1 06-25-2012 10:16 AM
What is Saturn's equivalent of "Check engine light"? Smog won't pass bulb check. harmono S-Series General 5 02-28-2012 10:17 AM
check engine light and coolant level light stuck on saturn/chev S-Series General 13 11-22-2011 08:20 PM
check engine light and antitheft light 2004 L300 jonus311 L-Series Tech 2 01-31-2009 08:55 AM
Check Engine Light W/ Reduced Power light saturnfreak01 L-Series Tech 5 01-24-2004 11:04 PM
