Old 05-13-2012, 10:17 AM   #1
mikehurl16
mikehurl16 is on a distinguished road
Default Fuel Injectors not Firing 1999 SC2
The car died while driving. Acted like a fuel pump had stopped. Towed it home and tested fuel prssure at the fuel rail and it passes. I checked the fuse for the fuel injectors and it was blown. I replaced the fuse and we tried to restart the engine. As soon as we tried to start the car the new fuse blew. What is the best way to find the source of the short?
Add to mikehurl16's Reputation
Rate the quality of this post and help mikehurl16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikehurl16 is offline   Reply With Quote
Old 05-13-2012, 10:23 AM   #2
PlasticCarsRock
PlasticCarsRock's Avatar
Default Re: Fuel Injectors not Firing 1999 SC2
Keep this in mind: fuel injectors are ground-switched: they have power all the time, and transistors inside the PCM connect them to ground, momentarily, to complete the circuit and fire them.
The first thing I would check is the somewhat exposed wiring near the injectors: look for any obvious damage (shorts). If everything looks good, it may be worthwhile to check the injectors with an ohmmeter to make sure none of them are shorted, but this isn't very likely. They should be 10-14 ohms.
Old 05-13-2012, 03:19 PM   #3
bluesl2
bluesl2's Avatar
Inspect where the wires go in between the intake runners,sometimes they chafe there and cause a short.
Add to bluesl2's Reputation
Old 05-13-2012, 03:35 PM   #4
Does the fuse blow when you turn the key to RUN or when you turn the key to START?
Add to madpogue's Reputation
injectors not firing Dukester_69 S-Series Tech 35 01-27-2011 09:46 PM
1999 Saturn SL2 - 3rd cylinder miss-firing engrforever S-Series General 10 06-26-2009 01:32 PM
swapped in new injectors, no fuel to fuel rail! DJboozeAlot S-Series Tech 6 06-05-2009 03:10 PM
firing order for saturn sc1 1999 smp7015 S-Series General 18 04-20-2009 06:39 PM
94' SC2 injectors not firing bryan_johnson S-Series General 4 09-07-2004 06:23 PM
