Old 05-09-2012, 09:29 PM   #1
Katherina88
Katherina88 is on a distinguished road
Default 2001 SL1 won't start occasionally
Yesterday my Saturn would not start. The key turns in the ignition, lights and radio go on but the engine does not turn over. I do not hear any sound from the car itself. I was towed to a garage and the car started fine for them. Battery test was good, starter test was normal, and charging test was ok. I picked up the car at lunch and everything was fine for a few hours until tonight as I again went to leave my child's daycare. This is the second day in the row I was towed. The tow truck driver spent 45 minutes and he was unable to start the vehicle. Any suggestions please?
Add to Katherina88's Reputation
Rate the quality of this post and help Katherina88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Katherina88 is offline   Reply With Quote
Old 05-09-2012, 10:14 PM   #2
Default Re: 2001 SL1 won't start occasionally
Automatic or manual transmission?
How many miles on the car?
Add to madpogue's Reputation
Old 05-10-2012, 01:29 AM   #3
adventureoflink
adventureoflink's Avatar
Is this occuring with the temp gauge being at the 1/4 line or higher? if so, classic starter heat stroke.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 05-10-2012, 05:28 AM   #4
Katherina88
Automatic with 195,000.
Old 05-10-2012, 05:32 AM   #5
Katherina88
No the temp gauge was below 1/4 line. I did try waiting over 1/2 between attempts last night but same result.
Old 05-10-2012, 09:41 AM   #6
Originally Posted by Katherina88 View Post
Yesterday my Saturn would not start. The key turns in the ignition, lights and radio go on but the engine does not turn over. I do not hear any sound from the car itself. I was towed to a garage and the car started fine for them. Battery test was good, starter test was normal.......... I picked up the car at lunch and everything was fine for a few hours until tonight ........This is the second day in the row I was towed. The tow truck driver spent 45 minutes and he was unable to start the vehicle. .....
No one is an expert on testing starters. No test exists for car starters, period. For anyone to say "the starter tests fine" doesn't know squat about starters and how they normally go through everyday wear and tear until they wear out. With 195,000 miles and most likely the original starter, yours is thoroughly worn out but very few "mechanics", much less tow operators, and even less car owners are familiar with starter issues. A simple process of elimination, if done by anyone that has some basic electrical/mechanical skills can perform a sequence of tests to arrive at and conclude a worn out starter. The basic steps to eliminate everything and arrive at a worn out/faulty/dead starter; battery, battery cables, their connections, and the ignition switch STARTING circuit. Eliminating each item will lead to the starter unless one of the items is the fault. An alternate test and the easiest to perform requires getting dirty; banging the starter body with a piece of 2x4 lumber or steel rebar a few times. If the starter suddenly works to get the engine running, this is the perfect example of a last ditch effort to confirm a worn out starter.
Fan/heater is on regardless of setting occasionally ilvtofu Astra General 3 06-29-2011 11:08 AM
Wipers turn themselves on occasionally PurdueGuy S-Series Tech 4 02-17-2011 09:58 PM
Car occasionally struggles at startup LotusLord S-Series General 4 08-07-2009 08:39 PM
coolant light goes on then off occasionally paulo Ion General 3 06-05-2009 09:58 AM
Speedometer occasionally gets stuck mkosem S-Series Tech 2 04-06-2003 01:48 PM
