Old 04-02-2003, 08:53 AM   #1
TrustyOne
TrustyOne is on a distinguished road
Default Motor mount
Can anyone give me a step-by-step on replacing the torque axis mount...I think that's the one that's causing my car to shake at idle and stop. Thanx
Add to TrustyOne's Reputation
Rate the quality of this post and help TrustyOne reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TrustyOne is offline
Old 04-02-2003, 09:47 AM   #2
mtlmutt
mtlmutt is on a distinguished road
Default
support the motor with a jack under the oil pan (carefully) jack up untill you see the motor start to move then stop. remove the 5 15mm nuts that hold it to the bracket and the front cover.if the studs come out from the front cover thats ok. the new mount is redesigned (again) and should come with new studs. put the new studs in, put the mount on and is stall the nuts on the front cover first then lower the jack and put on the 2 remaining nuts on the bracket. some people preload the mount by prying the part thats sits on the bracket side to force it closer to the fender. but thats really preference. once all 5 nuts are tight thats it.
Add to mtlmutt's Reputation
Rate the quality of this post and help mtlmutt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mtlmutt is offline
Old 04-02-2003, 01:40 PM   #3
grinnen30
grinnen30 is on a distinguished road
grinnen30's Avatar
Default
When you support the oil pan, use a block of wood to prevent damage.
Add to grinnen30's Reputation
Rate the quality of this post and help grinnen30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
grinnen30 is offline
How can I tell which motor mount I've got? flyhop S-Series General 12 02-26-2006 02:53 PM
Need motor mount dubsl2 S-Series General 1 11-27-2004 03:11 PM
motor mount metgol S-Series General 1 03-24-2004 04:01 PM
Motor Mount(s) dano92 Miscellaneous Tech 12 10-13-2003 02:34 PM
How much for motor mount? krasch S-Series Tech 10 01-31-2002 01:53 PM
