Old 05-01-2012, 02:14 PM   #1
Foxdog01
Foxdog01 is on a distinguished road
Default A/C Low Side Pressure Port for Recharge
Hello, I plan to recharge the A/C on my wifes 2008 Outlook. At a glance uder the hood I could not find the Low pressure port. I could not even see the compressor. Do I need to access this from below? Is it underneath, behind the front passenger side tire?
Any help in how to access the port so I can recharge her A/C. Thanks!
Add to Foxdog01's Reputation
Rate the quality of this post and help Foxdog01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Foxdog01 is offline   Reply With Quote
Old 05-01-2012, 06:25 PM   #2
Default Re: A/C Low Side Pressure Port for Recharge
If no one here has the location, try http://www.saturnoutlookforum.net/index.php. Members there should be able to have the answer.
My L300 has its compressor below the engine but service ports are usually determined by hose routing. The low pressure hose and service port is easily identified when compared to the high pressure hose; Returning refrigerant to the compressor, suction side is usually a gas so the hose diameter is larger than the high pressure discharge hose that contains a gaseous/liquid mix on its way towards the condenser coils in front of the radiator. Hoses from the firewall for a/c will have fittings as opposed to heater hoses. Separate and identify the a/c hoses and the larger diameter hose should return to the compressor; this hose should have the low pressure fitting that will only accept fittings made to connect here. A black or blue plastic cap will cover the service port.
The high pressure port will either be tucked away near the front of the engine along the side as the high pressure discharge hose (smaller diameter) will eventually lead to the condenser coil. Between the compressor discharge port and condenser coil is the high pressure hose that will have a smaller service port for high pressure monitoring when using refrigeration gauges. This service port should have either a red or black plastic cap.
Most, if not all, a/c service ports will be accessible from the engine area without resorting to crawling underneath. Even if you uncover the wrong service port, any attempt to attach designated refill/recharge/quick couplers won't allow a connection; low side fittings are larger diameter than high side fittings. This difference is to prevent catastrophic mistakes from anyone not familiar with the potential hazards of high pressure hook-ups.
When done attempting to service any a/c system, be sure to cap these ports tightly as these caps protect the schrader valves and provide the seal needed to prevent refrigerant from leaking out.
Old 05-01-2012, 10:35 PM   #3
Foxdog01
Fdryer,
I appreciate your informative quick response. I learned a good deal from it. I am still however struggling to find the location of the low pressure port. On the forum of the link you supplied, I found some discussions about recharging A/C, but none disclosed the location. I have been searching under Traverse, Acadia and Enclave as well, I have not found it. Not sure why it's not obvious under the hood like most other cars out there, but I'm still looking. Of course in the Outlook, when the pressure is low, the A/C doesn't turn on at all. The light blinks at you a couple times and it never comes on.
Old 05-02-2012, 12:15 AM   #4
Frankly I don't know why a (seemingly simple) question about a/c service ports can go unanswered. Perhaps a call to your local GM dealer may have someone give you the answer. Stopping by your local favorite repair shop? Posting some pictures here may help - one from each side of the engine.
Old 05-02-2012, 07:14 AM   #5
lsuduke
lsuduke is on a distinguished road
lsuduke's Avatar
2010 Outlook XE
Based on what I have seen online , it should be located very low, nearly out of reach near the evaporator filter. I'd love to validate that, but the GM Service Manual doesn't call out component locations that well anymore and my wife has the vehicle. But there was a post on the Acadia forum in 07 that stated its location. If I can find a pic, I'll send it along good luck.
Add to lsuduke's Reputation
Rate the quality of this post and help lsuduke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lsuduke is offline   Reply With Quote
Old 05-02-2012, 07:27 AM   #6
lsuduke
lsuduke's Avatar
2010 Outlook XE
Fdryer as far as how the question can go unanswered is these Outlook forums have nearly zero traffic, I come here for my Vue mostly, saturnoutlookforum.net has way more traffic as far as Outlooks go. The last new topic I saw here before this was oil pan replacement and it was up for a week. If a tree falls in the woods and nobody is there does it make a noise... If somebody posts and nobody sees it can you get an answer. Just my opinion.
Old 05-04-2012, 06:31 PM   #7
Amazingly, the picture gallery has two pics for view and I edited them to show one of the service ports at the front of the engine near the oil fill port.
Remove the black plastic cap and see if this is the low or high side service port. I'm guessing this is the high side port and won't allow attaching refill fittings. The line appears to be smaller in diameter, indicating it as the high pressure side. If so then the low pressure port would be located by the firewall near the two a/c lines attached to the HVAC fittings on the firewall. The same black plastic cap may be found on a small (aluminum) canister on the larger diameter aluminum line. The size of the engine and large plastic cosmetic cover may obscure locating the low pressure port.
Old 06-11-2012, 09:32 AM   #8
millzrm
millzrm is on a distinguished road
Did recharging help your issue of the light blinking? Ours is doing the same on +90 degree days but does eventually start blowing cold air. I dont hear any unfamilar sounds while the AC light is blinking so Im not sure if I just need a recharge or if something else is wrong like a leak..... I find it odd that we really only have an issue when its exceptionally hot out.
Add to millzrm's Reputation
Rate the quality of this post and help millzrm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
millzrm is offline   Reply With Quote
Old 06-16-2012, 03:08 PM   #9
ErnestoMM
ErnestoMM is on a distinguished road
1991 Astra XE
1991 Astra XE
Default ^^^^^^^^^^^
Sorry, what you mean?
Add to ErnestoMM's Reputation
Rate the quality of this post and help ErnestoMM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErnestoMM is offline   Reply With Quote
low side pressure service port location, 2003 L200 sean123 L-Series Tech 3 07-23-2017 01:01 PM
fuel pressure test port? nitroussaturn Vue Tech 7 11-01-2009 02:00 PM
AC low side pressure reached 120 during recharge mnw365 S-Series Tech 5 06-09-2009 12:04 PM
Oil pressure port for 2.2L Ecotec ? Samtherecordman Ion Tech 0 11-18-2007 11:06 PM
Manifold pressure port jentzsch23 Ion Mods 3 01-24-2007 02:27 AM
