Old 04-30-2012, 07:09 PM   #1
actnbill
actnbill is on a distinguished road
actnbill's Avatar
2006 ION-3 Sedan
Default High Idle and code P0507
I have a 2000 SL1 5 speed with about 120K......( my 4th Saturn )
Recently the SL1 idle has been racing up to 4,000 rpms and generating a P0507 code......
I have changed the ECTS with a brass one, a new IAC valve, cleaned the throttle body, new plugs and wires......
After I stop driving and set the parking brake the idle slowly lowers back to normal idle around 800 rpms.....( it takes about 1 minute to go from 4,000 down to 800 rpms.....and only when the car is parked...it races forever at 4,000rpm when I put it into neutral and coast down the road....)
Other than the high idle, it runs like a champ....
Anyone have any ideas what I can try to fix ?????
Bill
2003 L200
Add to actnbill's Reputation
Rate the quality of this post and help actnbill reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
actnbill is offline   Reply With Quote
Old 04-30-2012, 08:17 PM   #2
bluesl2
bluesl2's Avatar
Default Re: High Idle and code P0507
Check for vacuum leaks.
Add to bluesl2's Reputation
Old 04-30-2012, 08:24 PM   #3
ssewall
ssewall is on a distinguished road
Spray some carb cleaner around the #1 cylinder intake runner, on top and underneath. Try not to do it on a very hot engine. If the idle suddenly changes you have the intake manifold gasket leak that plagues 00-02 Sx1s. If this fails check for vacuum leaks elsewhere. Disconnected or broken vacuum hoses are good culprits.
Add to ssewall's Reputation
Rate the quality of this post and help ssewall reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ssewall is offline   Reply With Quote
Old 05-01-2012, 09:42 AM   #4
BV22
BV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of lightBV22 is a glorious beacon of light
2002 SC1
Idle at 4000 rpm indicates a major vacuum leak. Check the big hoses, particularly the one to the brake booster and the PCV valve hose. Could be the intake manifold gasket, but it would be a really tremendous leak to make the idle that high. Did you remove the throttle body to clean it, and if so, did you replace the gasket?
BV22
2002 SC1 5M
301k 12/17
Add to BV22's Reputation
Old 05-01-2012, 10:55 AM   #5
fm2200
fm2200 is on a distinguished road
2001 SL
Happy Re: High Idle and code P0507
Try changing the TPS that is a primary reason for a high idle. It's a cheap fix, if the TPS doesn't fix it. Then check all the other things like air leaks.
Add to fm2200's Reputation
Rate the quality of this post and help fm2200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fm2200 is offline   Reply With Quote
Old 05-01-2012, 11:22 AM   #6
PlasticCarsRock
PlasticCarsRock's Avatar
Don't just waste money throwing parts at it. It would be wise to test the TPS (see richpin video on youtube if you don't know how), but while a TPS can cause a high idle situation, they don't typically make it idle anywhere near that high.
Checking for vacuum leaks (particularly one this big) is pretty easy. Any brake cleaner (or carb cleaner, throttle body cleaner, propane, etc) sprayed near the leak will cause an audible change in the idle. (Obviously, you should be careful because you will be spraying something highly flammable near a running engine.)
With a leak large enough to rev to 4000 rpm, you can probably hear the leak just by listening with the hood open.
Old 05-02-2012, 03:30 PM   #7
actnbill
actnbill's Avatar
2006 ION-3 Sedan
update : I took some carb cleaner and sprayed it on all the vacuum hoses and intake manifold gasket area.....no change in high idle rpms.....
I took the throttle body off again and cleaned it really well....... no change to high idle......
Next, while the car was running, I unplugged the TPS electical connector from the throttle body and the rpms went down to 600-900 range instead of the 4,000 rpms I was experiencing......
Other than generating a code for an unplugged TPS sensor, the car idled pretty well..... ( it would wander a bit between 600-900 though )
My biggest question is should I replace the TPS, because the car will go right back to 3,000-4,000 rpms after I shut the car off and restart it with everything plugged in normally.....( a sign of a bad TPS is that the idle will reset after restarts )......mine doesn't...it stays high
2003 L200
Old 05-02-2012, 09:59 PM   #8
Remove the air intake tube so you can see the throttle body with the engine idling. If you can start and idle at 4000rpm, quickly block off the hole in the throttle body that's in front of the throttle plate.
Does the high idling drop immediately back down? And at what rpm?
Old 05-03-2012, 11:28 PM   #9
spettro9
spettro9 is on a distinguished road
spettro9's Avatar
2001 SC1
I have been having the same problem,
although after restarting car, everything seems normal..
i've already replaced idle air control valve, and cleaned throttle body once,
and the high idle still happens sometimes, when put in park (usually after longish or highway drive),
(or sometimes even stopped at a light, or going slow, i can feel that the idle seems a little more powerful, and if I quick drop the tranmission into neutral, the engine speed is higher than it should be)
anyway, I think it's the TPS. I have already bought it and will try change it soon.
PS: maybe related but maybe not, this morning my check engine light came on a few minutes after leaving home; a minute later I noticed that the temperature gauge was inactive, when the car should have been about up to operating temperature ("closed loop") already. I figured the 2 situations were related and sure enough when i got home, the scanner found
error P0118 - "Engine coolant temp sensor input above max acceptable range"
and pending errors P 0118 (ditto as above) and P0125 "Timed it takes to enter closed-loop fuel control is excessive"
In the parking lot of the auto parts store, I looked quick at the ECTS and the 2 wires to it looked literally like they were cut. Not melted or burned, but cut.
Don't have any clue how this would have happened, but I reconnected the wires using some 20 gauge braided wire I had and little butt connectors from radio shack. Was hard to fish them out of that massive spinal cord of wires but I got them, and put everything back pretty neat and safe. Will add a little liquid elec. tape tomorrow.
In driving this evening, temp. gauge functions fine again, and I think I still had the high idle at one point.
2001 Silver SC1, from craigslist in Clifton, NJ 2011/01/21, with 70k miles, $3K,
27 normal (winter 25 mpg) / 37-40 highway
(just have to watch oil a bit... seems to be 3/4 qt in 1000 miles, )
Add to spettro9's Reputation
Rate the quality of this post and help spettro9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spettro9 is offline   Reply With Quote
Old 05-04-2012, 08:15 AM   #10
actnbill
actnbill's Avatar
2006 ION-3 Sedan
I think I will have to get a new TPS sensor.....( I doubt it's the IAC because I just changed it and cleaned the throttle body )
If the TPS doesn't help, then I think I'll replace the intake manifold gasket.... ( My SL1 doesn't have power steering so I am guessing it's a bit easier to change the intake gasket on my car than one with ps. )
Bill
2003 L200
Old 12-01-2012, 12:20 PM   #11
spettro9
spettro9's Avatar
2001 SC1
I did indeed change the TPS since then, and it did fix the issue; no more revving...
PS
right now putting head + timing cover + oil pan back on... it seems head gasket developed oil leak near where alternator is (near the pressurized oil channel through gasket...)
Old 11-20-2017, 11:00 PM   #12
Mcstrikear12
Mcstrikear12 is on a distinguished road
I have a 2004 ion and recently hit a dog which destroyed the radiator and fan assembly. I've got everything back together but it runs at 3k rpm and runs kinda rough. Anyone have any idea what the problem could be? Could the fan being locked up by the radiator cause a sensor to go bad?
Add to Mcstrikear12's Reputation
Rate the quality of this post and help Mcstrikear12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mcstrikear12 is offline   Reply With Quote
High Idle then code 49 MacG S-Series Tech 2 04-01-2012 12:51 PM
Code P0507 and engine dies instantly at idle actnbill S-Series Tech 0 10-17-2011 07:21 PM
IAC Code and high Idle hammerheadlrrp S-Series Tech 7 05-12-2008 06:56 PM
high idle P0507 solved scotttomlin S-Series Tech 2 02-23-2006 06:47 PM
high idle P0507 scotttomlin S-Series Tech 2 02-20-2006 06:09 PM
