Old 04-28-2012, 05:39 PM   #1
mwheeler1982
mwheeler1982 is on a distinguished road
Mad 2006 Ion-2 High Idle After TB Cleaning
My 2006 ion with 78,000 miles was idling very rough. I replaced the fuel filter, inspected the air filter, and cleaned the throttle body. After starting the car back up, I got the "high idle" issue. It idles right at 1500 RPM.
I've read every thread out there about the high idle after TB cleaning issue. I can't seem to get my idle to settle down. I did not remove the TB to clean it, just sprayed the cleaner down in it and wiped it out.
Here's what I've done to try to fix the idle issue:
* checked for vacuum leaks
* left neg. battery cable off over night
* cleaned the MAF sensor with the appropriate cleaner.
* did the "turn key, no start, tb butterfly reset" procedure multiple times
* did the "drive above 44mph, then let off the accelerator" pcm re-program procedure. I've done this at least 40-50 times over the last week.
* took the car to the dealership to have the pcm re-flashed. the service sheet also says that they "re-set the IAC"
After all this, I still cannot get the idle to settle down. Does anyone else have any ideas as to what I can do to fix this? I never knew cleaning
Add to mwheeler1982's Reputation
Rate the quality of this post and help mwheeler1982 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mwheeler1982 is offline   Reply With Quote
Old 04-28-2012, 10:36 PM   #2
Samtherecordman
Samtherecordman is on a distinguished road
Samtherecordman's Avatar
2007 ION-3 Quad Coupe
Default Re: 2006 Ion-2 High Idle After TB Cleaning
Does it always idle at 1500 RPM ALL THE TIME or does it do it once it First Starts or it it just Random ???
Saturn Ion 3 Quad Coupe 3 with Sports Appearance package with Aura Pro Bass Shakers under the front seats, Kenwood Excelon Mono Amplifier and Infinity Kappa Perfect and I'm In Heaven!!!!
Add to Samtherecordman's Reputation
Rate the quality of this post and help Samtherecordman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Samtherecordman is offline   Reply With Quote
Old 04-30-2012, 08:41 AM   #3
mwheeler1982
Well, I'm not sure about it now. After I had the PCM re-flashed, I just drove the car home and parked it in the garage.
I drove it a bit around town yesterday and then to work today. At first start and after the car is warm, the idle is now 1250 RPM. If I let the clutch out a bit to get the RPMs below 1000, it'll start idling at around 900RPM (normal) until I turn off the car. Next time I turn on the car, it'll start idling at 1250 RPM again.
This was never a problem until I cleaned the TB, so I'm guessing it has something to do with that. Surely it's not possible that cleaning the TB has somehow ruined the PCM??
Old 04-30-2012, 09:28 PM   #4
2006 ion2
2007 ION-2 Sedan
no, it isn't.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
high idle and SES after throttle body + EGR cleaning Troy35 S-Series General 25 02-26-2011 10:09 PM
high idle after cleaning wizetekie Ion Tech 34 05-08-2009 02:10 AM
high idle after cleaning throttle body shur35 L-Series General 2 04-05-2009 02:15 PM
2001 SL1 high idle after cleaning Throttle Body rickystarshine S-Series Tech 6 11-19-2006 08:33 AM
Need Help Why does my idle shoot so high after cleaning the IAC? turbobuick33 S-Series General 1 08-06-2005 07:43 PM
