Old 04-21-2012, 09:02 AM   #1
cvanloon
cvanloon is on a distinguished road
2001 SL2
Default Saturn SL2 blower motor won't work
If I hook up the blower motor directly to a battery (car battery) it works fine.
I checked the power and the ground. Coming from the switch, right at the point before they connect to the blower motor. Ground is grounded and there is power coming from the switch.
When I hooked it up again it worked for a little bit (10 seconds) when I turned the switch off and back on again it stopped working. Checked the power again... there is still power.. any ideas?
Add to cvanloon's Reputation
Rate the quality of this post and help cvanloon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cvanloon is offline   Reply With Quote
Old 04-21-2012, 09:05 AM   #2
Default Re: Saturn SL2 blower motor won't work
Yes, but I need the year and model of your car. If you put the info into your profile it will show up in the left hand frame and everyone will have it.
Your problem should be an easy fix.
Old 04-21-2012, 09:13 AM   #3
cvanloon
2001 SL2
Thanks! 2001 Saturn sl2
Old 04-21-2012, 09:15 AM   #4
Does it run in any speed at all?
Old 04-21-2012, 09:18 AM   #5
cvanloon
2001 SL2
No... It did for a little then shut off
2001 Saturn sl2
Old 04-21-2012, 09:24 AM   #6
OK, this is the same problem you are having. http://www.saturnfans.com/forums/sho...d.php?t=179483 Most likely the failure is located at the same spot, F-2 on the black 68 pin connector on the r4ar of the inside fuse panel. You can get at it from the DRIVERS side of the center console, just take off the side kick panel. Locate F-2 and wiggle it while the blower is turned on. If it suddenly runs then this is what needs fixing. There is a schematic that Rulley73 posted that shows all the wring. You do not have to take the car apart to fix this.
Old 04-21-2012, 09:46 AM   #7
cvanloon
2001 SL2
Wow. thank you very much for your help. Ill try it out and let you know how it goes!
2001 Saturn sl2
Old 04-21-2012, 09:52 AM   #8
Just go slow and it fixes easily.
Old 04-21-2012, 02:52 PM   #9
cvanloon
2001 SL2
You are awesome... worked
2001 Saturn sl2
Old 04-21-2012, 03:01 PM   #10
Thanks! I am sure my trolls will be upset.
If you have it properly tightened it will not do this again.
2006 Saturn Vue Blower Motor Totally Inop slacke Vue Tech 13 01-25-2018 09:30 PM
Blower motor does not work in high 01l100 L-Series Tech 10 06-05-2011 05:03 PM
2000 saturn ls2 blower motor how to?? omgwtf L-Series Tech 1 11-22-2009 11:35 AM
2004 saturn vue , ac/heat blower motor no power iamyourtech Vue Tech 3 09-08-2009 09:40 PM
HVAC Blower Motor Dying...can one fix motor? flyhop S-Series Tech 2 09-28-2006 09:08 PM
