Old 04-18-2012, 07:53 PM   #1
Starmonkey
Starmonkey is on a distinguished road
2000 SL
Default Strange grinding noise when turning steering wheel
Hello,
I've got an unusual noise when I turn the steering wheel sharply in either direction - like when you are parking. It is sort of a clicking/grinding sound - almost like large sand granules being ground inside the steering rack assembly. I chalked it up to CV joint noise, as I had other symptoms (front end vibration at steady speed and the "rocks in the hubcap" sound on sharp turns), although I thought it strange that the sound would present even if the car was not moving.
I recently changed both axle shafts (which fixed the vibration and rocks in the hubcap sound), and while I hade the tie-rod ends undone from the steering knuckle with the front end on jack stands, I tried turning the wheel, expecting to not hear the noise – but to my surprise I did.
I believe having the tie rod ends disconnected eliminates anything in the hubs, struts or axles because they weren't moving. The only thing I can think of is the steering rack itself or the U-joints in the steering column.
Before I go to my local P&P for a whole rack and steering column, Has anyone else had this issue (I have yet to have a unique problem in this forum)? It is a 2000 SL with manual steering and a bit over 200K miles, most of which in the uneven pavement in California (sort of rough on suspension). The axles, wheel bearings, and control arms/ball joints are new. Thanks in advance!
Add to Starmonkey's Reputation
Rate the quality of this post and help Starmonkey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Starmonkey is offline   Reply With Quote
Old 04-18-2012, 09:13 PM   #2
off-track
off-track's Avatar
Default Re: Strange grinding noise when turning steering wheel
Mine makes a "creaking sound" when the weather is hot. Does that sound right? So far, I've just put up with it.
If you dig around through old posts there was one a long time ago that described a similar problem that was related to a bearing on the lower end of the steering column. IIRC, the fix required fabbing in a new beefier bearing.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 04-19-2012, 11:39 AM   #3
Starmonkey
2000 SL
It is sort of a creaking sound –could be the same issue. I haven’t noticed a difference with temperature, but there isn’t a huge temperature variation here – or mine might just be further gone.
Like you I’ve just put up with it. It doesn’t seem to have any effect on performance, but it’s a bit annoying – particularly with all the new front end parts.
I will do some digging in the posts, now that I know what to look for – thanks!
Old 04-19-2012, 11:59 AM   #4
DB42
DB42 is on a distinguished road
DB42's Avatar
Originally Posted by Starmonkey View Post
Hello,
This may sound to easy but check where your plastic engine splash guards are make sure they are attached and not rubbing on your tires when you turn sharp. My daughters grand prix had a very loud grinding noise happen when she turn the wheel sharply going slow. I was about to replace wheel bearing when all of that looked good. then while I had the car on jacks I had her get in side it while putting it in gear and turning the wheels and sure enough I heard the noise and saw where the right wheel was rubbing on the engine splash guard cause the guard was out of place. it made a big grinding sound like metal with a few plastic zip ties I fixed the noise! Man if I would of brought that to a shop they could of said wheel bearings or something else and ripped me off.
1997 SL2 162000 miles
Add to DB42's Reputation
Rate the quality of this post and help DB42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DB42 is offline   Reply With Quote
steering wheel makes noise when turning prioris S-Series Tech 6 10-21-2011 05:01 PM
Strange noise when turning the wheel Tercero S-Series Tech 2 11-30-2010 12:44 PM
2003 Vue Steering Wheel Tunk Noise When Turning Wheel kencat Vue General 6 03-05-2010 06:06 PM
Noise when turning steering wheel xybaby S-Series General 2 10-21-2006 06:12 PM
Grinding noise when turning steering wheel left and/or right rtaylor Vue General 4 01-18-2004 10:27 PM
