Old 04-17-2012, 10:47 AM   #1
therobinator
therobinator is on a distinguished road
Default Bad wheel bearings - symptoms and diagnosis
I dropped my 2003 VUE off this morning at a highly recommended and supposedly very trustworthy mechanic, for a few symptoms. First was a Service Engine Soon light which turns out to be an oxygen sensor. Second is brakes that need replacing anyways. But most majorly are these: (1) When traveling at highway speeds, there is a whirring/buzzing noise which disappears when the steering wheel gets turns to the right. (2) There is also a loud rattling/shaking noise coming from the steering column….this happens only when braking (especially at highway speeds for example coming off an exit ramp), or when driving (without braking) on a bumpy street.
The mechanic says the problem is bad wheel bearings. It makes sense to me that the whirring/buzzing noise could be bad wheel bearings, but I don’t understand how bad wheel bearings could or would cause the rattling/shaking in the steering column while braking or while cruising on a bumpy street. Can anyone explain this to me? Also, if the noise disappears when turning to the right, that means the left bearing is the bad one, correct?....so, why would I bother replacing both? Finally, he wants to charge me $1,200 to do all the repairs….brakes, oxygen sensor, and wheel bearings….is this reasonable (I am in the Boston area)?
Thank you!!!
Add to therobinator's Reputation
Rate the quality of this post and help therobinator reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
therobinator is offline   Reply With Quote
Old 04-17-2012, 11:02 AM   #2
bluesl2
bluesl2's Avatar
Default Re: Bad wheel bearings - symptoms and diagnosis
The shaking in the steering wheel when braking is most likely warped or rust pitted rotors. Hopefully when he changes your brakes he puts new rotors on. The noise you hear when slightly turning the wheel is most likely a wheel bearing going.
Add to bluesl2's Reputation
Old 04-17-2012, 11:44 AM   #3
Midnight13
Midnight13 is on a distinguished road
Midnight13's Avatar
1998 SL
Thank you!!!
Brakes-($80)- you can get at Autozone for about $30 each rotor, and $20 for a set of pads, my ceramic pads were $15 on ebay.
Bearings-($100) whether on ebay or at Autozone, they run about $50 for each one. Typically when you replace something on one side of your axle, you replace both sides. Would you only replace one rotor or pads if only one side squealed?
Oxygen sensor- about $80 at Autozone
Less than $300 worth of parts and they want to charge you $900 more for labor????
I'm a chick and I did all these jobs already on my Vue! Well, with a little help from my husband getting the hubs off.
The mechanic sounds right in the diagnosing of everything. As for the cost to fix, either get a quote from another place, or do it yourself. You can even obtain the parts for them so you don't get the "markup" on parts from them too.
"Not for human consumption!" - Peas in the Pod
http://www.facebook.com/#!/pages/Peas-in-a-Pod/160649663950771
Add to Midnight13's Reputation
Rate the quality of this post and help Midnight13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Midnight13 is offline   Reply With Quote
Old 04-17-2012, 03:07 PM   #4
therobinator
I don't know, I am no expert, but according to AutoZone.com (having typed in my year, make and model), the wheel bearing/assemblies are a minumum of $162 each for my VUE. Rotors are $40 each, oxygen sensor $68 at minimum, brake pads $20. That puts me at a minimum of $492 for parts alone, assuming he's only replacing the front bearings and buying the minimum quality products. It would be more if he goes for higher quality brake pads or O2 sensor. I think where you and I are differing in our calculations is on the bearings. According to AutoZone, I couldn't buy *just* the bearings, I'd have to buy the whole assembly. And maybe the prices are different by area (the website asked for my zip code before it would show prices). Perhaps those are the differences. It's still over $700 in labor, though....and I will of course expect an itemized bill, and I will deal with him sternly if things seem off.
Old 04-17-2012, 10:52 PM   #5
mdbuilder
mdbuilder is on a distinguished road
Seems fairly reasonable to me, I seem to remember my first brake job @ 125K miles was 600ish for all 4 corners. I had a wheel bearing melt down which cost what your estimate is all by itself but that bearing was litterally fused in place, parts had to be torched off the car to change it
Don't let that bearing go too long
Add to mdbuilder's Reputation
Rate the quality of this post and help mdbuilder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mdbuilder is offline   Reply With Quote
Old 04-20-2012, 08:24 AM   #6
therobinator
It's all fixed now. Thanks all for your advice. The problem now is that the Service Engine Soon light came back on. New thread post about that in a minute....
Old 04-21-2012, 09:29 PM   #7
mdbuilder
Check that the gas cap is tight, loose cap will set off the light. It'll take a few days to go out after tightening.
wheel bearing diagnosis BKbroiler Aura General 8 06-21-2016 02:27 PM
Front wheel bearings: Ball or Needle bearings ?? Luke S-Series Tech 12 03-26-2011 07:25 PM
without putting it on a hoist, what are some symptoms of a blown wheel bearing? camzshaft S-Series General 9 01-19-2011 05:29 PM
Wheel Bearing Diagnosis Cudajas S-Series Tech 7 11-22-2010 10:56 PM
1999 SL2 Wheel Vibration Diagnosis dgmess S-Series Tech 6 02-22-2005 01:54 AM
