Old 04-16-2012, 08:46 PM   #1
cooxl231
cooxl231 is on a distinguished road
cooxl231's Avatar
Default Transmission fluid change?
Hello everyone.
My 03 vue has hit 77k miles just recently. What I notice after I drive the car is that the transmission tends to get clunky after I drive it awhile.(such as the car sits just below 2000rpm at around 25-35mph, than it shoots up and drops back down and you feel the car jitter) Im not sure if this is because of dirty transmission fluid? I believe this car does not have a dipstick for it because I couldn't find it when I popped the hood.
Im not really familar with the transmission fluid replacement mileage on this car, Im not sure if it falls under the 100k maintenance everyone talks about, or if it needs to be done every so often. I am not sure if this car ever had the transmission fluid replaced.
Basically getting to the point, should I have it done? And will I have a more smoother shift in gears or am I having a transmission slip / failure?
2003 Saturn Vue AWD 3.0 V6
Add to cooxl231's Reputation
Rate the quality of this post and help cooxl231 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cooxl231 is offline   Reply With Quote
Old 04-17-2012, 02:36 AM   #2
Chazberry
Chazberry's Avatar
Default Re: Transmission fluid change?
It's an easy DIY and it can't hurt to see if this cures your problem. It's recommended 100k maint, but most folks here say it should be done more often. Some pics of the procedure here . . .
http://www.saturnfans.com/forums/sho...d.php?t=158509
Add to Chazberry's Reputation
Old 04-17-2012, 05:18 PM   #3
cooxl231
cooxl231's Avatar
How many qts? (Im guessing 4.3?) and whats the BEST fluid? ATF Z1?
Old 04-17-2012, 06:27 PM   #4
Chazberry
Chazberry's Avatar
That's about what typically drains out.
No - you want the T-IV
Old 04-17-2012, 07:57 PM   #5
cooxl231
cooxl231's Avatar
Yeah that sounds good. Since this isn't a full flush as what I read, is it worth it to do it myself rather then spend the few bucks and get a full flush since im not flushing everything?
Old 04-17-2012, 08:10 PM   #6
Chazberry
Chazberry's Avatar
Everyone here says never "flush" - just "drain and fill".
Old 04-17-2012, 08:21 PM   #7
cooxl231
cooxl231's Avatar
Alright. Reading a little more in depth on this, is there any local auto parts stores that carry this or am I going to have to go through toyota or GM?
Old 04-17-2012, 08:29 PM   #8
Chazberry
Chazberry's Avatar
I'm not sure - I got mine from Toyota.
Old 04-17-2012, 08:32 PM   #9
cooxl231
cooxl231's Avatar
Thanks Chazz!
Old 04-17-2012, 08:36 PM   #10
Chazberry
Chazberry's Avatar
Thanks Chazz!
You're welcome. I hope it makes your tranny feel better.
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 35 06-30-2017 06:47 PM
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 05:57 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 05:04 PM
Change Transmission Fluid hovercraftmk2 S-Series General 7 02-19-2008 12:55 PM
transmission fluid change Zigmund555 S-Series Tech 10 12-19-2002 04:35 PM
