Old 04-12-2012, 06:16 PM   #1
softdrinkman
softdrinkman is on a distinguished road
Default 2 trans questions for swappage
ok,im going this weekend to try to pick a maunal to swap out with on my car.off hand i remember i need the trans & clutch,shift linkage,slave cylinder,clutch master cylinder,clutch pedal,shifter and shift conslole.what am i forgetting?
and second question.how can i tell the difference between the mp2 and mp3 trans at the junkyard?any helpfuls would be awesome (oh and im driving 1999 sw1)
Add to softdrinkman's Reputation
Rate the quality of this post and help softdrinkman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
softdrinkman is offline   Reply With Quote
Old 04-12-2012, 06:26 PM   #2
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1997 SW2
Default Re: 2 trans questions for swappage
Least effective way is to assume it hasn't been messed with so a SOHC will have a MP2 and a DOHC will have an MP3. '98-'02 MP2's have the longest 5th gear if mileage is what you want.
Between the top transmission mounting bolts (on the bell housing) and down an inch or so, clean all the grime off and it'll say MP2 or MP3 (MP6 or MP7 for the odd looking paperweights). It's hard to read as it's a dot matrix print, but it's there. I know a couple people have posted a picture of exactly what/where to look but I can't remember who.
Only need the 5spd shifter boot, not the whole console. Doesn't matter what model it's from as long as it's from the same generation as your center console.
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 04-12-2012, 06:35 PM   #3
Low Saturn
Low Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to all
Low Saturn's Avatar
2008 AURA XE
From the junkyard: Transmission, PCM, shifter, shift cables, shifter boot, shift knob, clutch hydrolics, clutch pedal, brake pedal, clutch fork and all related hardware (nuts, bolts, clips).
New from the autoparts store: Flywheel, clutch disc, pressure plate, release bearing.
A MP2 will be attached to a SOHC engine and a MP3 will be attached to a DOHC engine. Also the second, third and fourth digits on the transmission id code will indicate what transmission it is. It will say MP2 or MP3 for a manual or MP6 or MP7 for an automatic.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevy Suburban
-2008 Saturn Aura XE V6
Im out of EGR adaptors & ECTS connectors.
Old 04-13-2012, 05:08 PM   #4
softdrinkman
awesome!thanks both of you guys very very helpful!
Old 04-13-2012, 05:16 PM   #5
softdrinkman
only other question is.will it stiil work with the auto pcm?im asking since if i find say a 97 or 98' trans and put into my car,will that 97 -98 pcm run my 1999 sohc properly?(and no im not modding the sohc im building a dohc on the side)if not ill keep looking for a 99 trans but if i can get away with it ill run the old pcm.
94 SL2----Manual Trans questions 2NDSOUT S-Series Tech 2 05-01-2008 06:46 PM
Two quick trans questions Ryan from Ohio S-Series Tech 3 03-29-2007 01:45 AM
Engine Swappage getz999 S-Series Mods 18 03-28-2005 10:04 PM
Trans & PCM questions cybrsk8r S-Series General 2 01-13-2004 09:07 PM
Manifold Swappage JhnBrackett General Saturn Discussion 11 11-27-2003 09:25 PM
