Old 04-08-2012, 12:05 PM   #1
IonDrover
IonDrover is on a distinguished road
Question Ignition Switch?
By the title I know that you know im having starting problems. I've read a lot of threads on this issue and am leaning towards the ignition switch but want to get some opinions. Sometimes I get nothing, not even the fuel pump kicking in. Also at times I will get multiple loud clicks with the key turned to start then will continue to start after the key is let go back to the run position. would the switch cause this? Once started and driving, sometimes will loose power for a split second and the check engine light will flash on then go right off. Aswell, the car will shut off completely every now and then. Will the ignition switch cause all of these problems? BTW, 2.2 ecotec, manual trans, less than 90 000 KMs
Add to IonDrover's Reputation
Rate the quality of this post and help IonDrover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IonDrover is offline   Reply With Quote
Old 04-08-2012, 12:09 PM   #2
IonDrover
Default Re: Ignition Switch?
by lose power i mean the rpms will drop off and the car will give a little buck then go back to normal. THX in advance for advice!
Old 04-08-2012, 01:14 PM   #3
FenderGuitars77
FenderGuitars77 is on a distinguished road
1996 SC1
1992 SL1
Two things I would check:
Ignition switch: they're less than $30 at Advance, and easy to replace, I'd do it anyway as preventative maintenance if you haven't already.
Bad ground: this is free to check, just check your grounds for rust or corrosion. I dunno where the grounds are on a base Ion, but on my Redline my car wouldn't start properly and it turns out the ground right near the ABS module under the hood was rusted and I had to move it to clean metal and my car started no problem.
FENDERGUITARS777
2006 ION Redline
1996 SC1
1992 SL1
WANT TO SAVE 5% OFF YOUR NEXT PURCHASE FROM REDLINE GOODS?
http://www.redlinegoods.com/cgi-bin/uam/x.cgi?a=r&id=1&aid=664&p=2
Add to FenderGuitars77's Reputation
Rate the quality of this post and help FenderGuitars77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FenderGuitars77 is offline   Reply With Quote
Old 04-08-2012, 04:44 PM   #4
IonDrover
Thx, I will try it and hopefully the switch fixes it. Ill post an update asap
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 03:30 PM
Saturn Ion 2 (2007) Ignition Lock or ignition Switch Manual Transmission infinitezero Ion Tech 5 11-25-2011 04:47 PM
Ignition Switch operator john S-Series Tech 2 09-27-2011 08:20 PM
Ignition Key Switch reevesjo Ion General 4 05-31-2011 08:58 AM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 01:09 AM
