#1 | ||||
![]() Join Date: Aug 2010
So my transmission is making a loud noise out of the left side where the cv shaft goes in. I'm assuming its a bad bearing or the like, it otherwise drives fine I've been driving it for over a month like this. I got a quote from a reputable local transmission shop for $800 labor, plus the cost of the transmission to replace it. I've been looking in my shop manual, and it seems like a pretty straight foward process, just that it will take a good chunk of time to do it. I've searched the forum and can't find anything on anyone doing this, has anyone ever done this and if so can you give me your advice and any information about difficulties you had. I'm still in the deciding stage of whether to attempt it myself, it would save me $800, and seeing as how most trannys around here are running ~$600 it would definitely help. As far as my skill set, I've never replaced newer fwd transaxles, I've only dealt with rwd trans in older vehicles, and I have done the timing belt/water pump/ thermostat/ spark plug job on this car as well as countless other repairs like wheel bearings etc. Thanks in advance for your response!
#2 | ||||
![]() ![]() ![]() Join Date: Jul 2005
Are you sure it's a noise in the trans or a bad wheel bearing? Wheel bearings go bad quite often in the vues. I would suspect that first over the trans.
#3 | ||||
yes, I replaced both wheel bearings because of this a month or so ago. After I did those and it still made noise, I put the entire car on jack stands and listened for noise, it was coming from the left of the car so I took that tire off. A friend gave the car some throttle, and I could clearly hear it from the bottom of the trans as well as from the wheel well side, I jammed my head in there good to make sure
#4 | |||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
Whine or growl could be no fluid, low fluid, or wrong fluid. Another member is exchanging a transmission for some reason - view the following thread and perhaps send a personal message to check progress: http://www.saturnfans.com/forums/sho...d.php?t=178796 ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#5 | |||||
http://youtu.be/YcgMoiHF3DY The first is while inside the car, the second view is when I had it up on jack stands. As far as fluid goes, I'll check the level but it engages and drives fine. I have changed the fluid three times, using valvoline Maxlife dex/merc ATF fluid as suggested on the forum.
#6 | ||||
I guess I'd call that a "rasp-type" noise when operating at lower RPM.
I don't see any wobble (movement) of the differential stub when axle was rotating. Are you certain there's not a problem with the left front brake? Perhaps the dust shield is touching the rotor? I believe I'd pull the axle and see if noise persists before buying another transmission. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
| Thread Tools | |
| Display Modes | |
| ECM replacement 2002 VUE 3.0 | texan | Vue Tech | 1 | 04-11-2011 02:41 PM |
| Transmission cooler/radiator replacement when transmission is bad? | infinitewisdumb | S-Series Tech | 2 | 04-16-2010 08:59 AM |
| 2002 SL1 Transmission issues, "reverse slam", P0708 code, transmission range sensor | mt_spiffy | S-Series Tech | 20 | 12-14-2009 01:17 PM |
| 2002 L-100: Serpentine Replacement | Fez | L-Series Tech | 1 | 03-06-2009 07:31 PM |
| Replacement Boot for 2002 Vue | sandbug01 | Vue General | 2 | 12-13-2006 01:23 AM |
