Old 03-27-2012, 08:16 PM   #1
rob.ski
rob.ski is on a distinguished road
Default Service ESC Service Traction
I have a 2008 Aura (3.5) and have been getting Service ESC, Service Traction messages randomly for a long time. At first it would only happen when damp or raining. Dealer couldn't reproduce the problem. Now it happens every time I drive the car. Checked DTC and had 2 P0106 codes. Can this be related? Also, the car has low speed idle issues. When I come to a stop (without A/C on) idle bounces around and drops to around 500 rpm. Some times it feels like it will stall.
Add to rob.ski's Reputation
Rate the quality of this post and help rob.ski reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rob.ski is offline   Reply With Quote
Old 03-27-2012, 08:27 PM   #2
whiteshadow
whiteshadow is on a distinguished road
Default Re: Service ESC Service Traction
A P0106 could be caused by:
-Bad MAP sensor
-Water/dirt intrusion affecting MAP sensor connector
-Intermittent open in the reference, ground, or signal wire for the MAP sensor
-Intermittent short in the reference, ground, or signal wire for the MAP sensor
-Ground problem due to corrosion causing intermittent signal problem
-A break in the flexible air intake duct between the MAF and the intake manifold
-Bad PCM (do not assume the PCM is bad until you've exhausted all other possibilities)
http://www.obd-codes.com/p0106
07 aura xr
98 explorer 5.0
93 miata, not stock
77 f150
im not nice
number of times ban.T
1
Add to whiteshadow's Reputation
Rate the quality of this post and help whiteshadow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
whiteshadow is offline   Reply With Quote
Old 03-28-2012, 12:17 AM   #3
greenman
2009 AURA XE
Originally Posted by rob.ski View Post
... had 2 P0106 codes. Can this be related?
Yes they are related. Either a bad MAP sensor or a fault in it's wiring harness.
Add to greenman's Reputation
Old 03-28-2012, 07:29 PM   #4
rob.ski
I pulled the map sensor to inspect. Didn't have a vacuum pump to test it. Put it back in and no messages yet. Maybe the problem is in the harness. I'm still having low speed idle issues. Dropping below 500 rpm occasionally when stopped and in gear. Is there an IAC valve on this vehicle? All I see on the throttle body is MAF & vacuum valve.
Old 03-29-2012, 01:23 AM   #5
greenman
2009 AURA XE
There is no IAC valve. Always a good idea to clean the MAF sensor & TB if you haven't lately. If you can access a scan tool with live data you can see what the MAP sensor is up to.
Old 03-30-2012, 06:47 PM   #6
rob.ski
I got some CRC MAF cleaner and did the MAF sensor. I must say, between that and fiddling with the MAP sensor the car is running much better. Idle is good when stopped in gear and have not seen another Service ESC Service Traction message (yet). Not convinced I actually fixed anything (probably bad connection on that map sensor) but, at least I know where to look next time. Thanks a lot for info the guys.
Rob
Service Traction/Service ESC warnings Dev_56 Aura General 6 02-22-2012 02:37 PM
Service traction?!?! help Mikey07! Aura General 8 12-13-2011 10:05 AM
Service Traction and SES lighting up cverstij Aura General 23 11-05-2008 11:05 AM
Service Traction ?? humfrz Aura General 3 10-19-2008 01:01 PM
Service Traction issues LoriO Aura General 6 04-17-2008 03:34 AM
