#1 | ||||
![]() Join Date: Apr 2007
Has 120k miles. I rebuilt the enigne after timing chain went out 2nd time. So I thought may as well install new clutch too was 80% gone PPlate TO bearing and all. bled the system and the clutch pedal will not go down. I had to replace master cylinder cause I broke the rod. Bleed fine checked slave fluid comes out when little valve is in and pedal depressed. Tried pushing a screwdriver in the trans hole but dint wanna push too hard cause the mount from inside is plastic. Can the TO bearing be stuck i lubed the shaft and splines, i have changed many a clutch. I really dont wanna take the tranny back out cause you have to remove the subframe and I dont have a lift.
Any Ideas Please Thanks Mike
#2 | ||||
How did you bled the clutch hydraulic system when the pedal won't go down?
Is the hydraulic line from the master all the way into the line that goes to the slave? There is a check valve in the line from the master and if the line is not into the slave fitting all of the way there will be no movement of the fluid to let the pedal move. ... A lousy day in paradise is still a day in paradise.
#3 | ||||
The pedal wont go down after bleeding. It bled fine. I took the line off pushed in the check valve and had someone push the pedal lightly and got fluid so Hydrolics are OK. There is a metal tip inside the trans that opens the check valve. Im gonna try to push it in manually and use a socket so I dont mess up the tip.
Thanks
#4 | ||||
Problem Solved the slave was not in all the way. Even though the metal retaining clip went in I had to turn and push in the slave cyl and had some spring like back pressure and a notch so it went flush.
Thanks Mike ![]()
| Thread Tools | |
| Display Modes | |
| Possible clutch problem in 2006 4cyl manual Vue | wmacblue | Vue General | 3 | 08-16-2011 09:26 AM |
| Need opinions on 2002 4cyl AWD vue | Infinitrium | Vue General | 6 | 05-01-2011 10:48 PM |
| 04 VUE 4cyl, manual, Intermittent AC? | sagacious | Vue General | 11 | 04-21-2011 07:09 PM |
| 2002 4cyl. A/C oil... | DavidBo | Vue Tech | 8 | 04-02-2010 06:22 PM |
| Considering 07 4cyl manual | Weird1 | Vue General | 39 | 02-12-2007 02:15 AM |
