Old 03-11-2012, 06:05 PM   #1
white chocolate
white chocolate is on a distinguished road
Default Cylinder 1 & 4 Misfire
2001 SL2 auto 4 door about 100xxx miles
After doing a head gasket, the car is running on cylinders number 2 and 3 only.
Replaced coil pack on 1 & 4 and the plug wires are getting nothing. The igntion module passed autozones test, so i replaced the coil pack on 1&4 and the plug wires and cylinders are still not firing at all. Ingectors are firing and i also replaced the coolant sensor in the side of the head. It has new plugs, they were autolite double platinum but i read to run NGK so i replaced them with NGK single platinums. Still nothing.
Please, help before i set the car on fire and push it off of a bridge!
thnaks!
Add to white chocolate's Reputation
Rate the quality of this post and help white chocolate reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
white chocolate is offline   Reply With Quote
Old 03-11-2012, 06:10 PM   #2
jsnead
jsnead is on a distinguished road
2002 SL1
Default Re: Cylinder 1 & 4 Misfire
thnaks!
If I'm correct I believe it's supposed to be coppers not plantium plugs. Have you done a compression test? Also, any DTCs?
Add to jsnead's Reputation
Rate the quality of this post and help jsnead reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jsnead is offline   Reply With Quote
Old 03-11-2012, 06:13 PM   #3
white chocolate
DTC?
The issue im having is absolutely no spark to plug wires 1&4. They ignition moduel is good as well as the coil packs.
I just bought what autozone had for sake of trouble shooting, the double platinum were special order and i didnt want to wait...
Old 03-11-2012, 06:14 PM   #4
jsnead
2002 SL1
DTC is fancy for check engine light. Also, I'm assuming the previous head gasket was blown?
Old 03-11-2012, 06:26 PM   #5
white chocolate
yes, i forgot to mention i have an SES. and yes, the previous hedagasket was blwon
Old 03-11-2012, 06:43 PM   #6
jsnead
2002 SL1
Whats the SES? Also, did you check for head and block flatness with a straightedge when you replaced the head gasket?
Old 03-11-2012, 06:59 PM   #7
white chocolate
i'm not sure what the SES is and cant take it anywhere to have it checked due to lack of license plates and insurance.
i did not check anything with a straight egde. the car was disassembled, cleaned, and reassembled.
im not sure whats going on. The plugs in 1 and 4 are covered in and smell like gas. the plugs in 2 and 3 come out covered in soot.
Old 03-11-2012, 07:00 PM   #8
Go to a wrecking yard and get an ignition module from the same year car and try it.
If you have spark on 1-2 and none on 1-4 then the module is the best suspect. I have seen a few modules that fail for one coil only.
Add to ssicarman's Reputation
Old 03-11-2012, 07:03 PM   #9
white chocolate
even if the module was tested and passed? not sure how accurate autozones tester is...
Old 03-11-2012, 07:17 PM   #10
jsnead
2002 SL1
There are arguments wether any kind of electrical testing at the local auto parts store is accurate. Failure is possible during operating conditions but can pass a test.
Old 03-11-2012, 07:21 PM   #11
white chocolate
well i guess this is my next step then. i am very frustrated and running out of ideas here!
Old 03-11-2012, 07:25 PM   #12
jsnead
2002 SL1
It can be frustrating
Cylinder 4 misfire jkurtz831 S-Series Tech 1 07-03-2011 11:05 PM
Help with Cylinder 1 misfire chris233 Ion Tech 11 01-06-2009 06:03 PM
Cylinder 3 Misfire and more, Please Help! RedRed S-Series Tech 7 09-24-2007 10:14 PM
96 SL2 - cylinder 4 misfire budward S-Series Tech 9 03-22-2007 10:00 PM
97 sl1 #2 cylinder misfire help!! 2RINGS S-Series Tech 7 04-03-2006 05:47 PM
