Old 03-11-2012, 05:56 PM   #1
TrotFox
TrotFox is on a distinguished road
1992 SC
2006 VUE 2.4L
Default JY EGR installed, verify tubes?
Hi all!
I brought home an EGR from the yard yesterday and today had the opportunity to install it. Could someone look at the photos and let me know if this is how the solenoid is supposed to hook up? Also, what used to mount there in the second photo?
THANKS!
Trot, the hopeful, fox...
Red 5spd Fiero Formula
Grey 5spd '06 Vue
Red '15 PriusC-4
Add to TrotFox's Reputation
Rate the quality of this post and help TrotFox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TrotFox is offline   Reply With Quote
Old 03-11-2012, 06:10 PM   #2
Default Re: JY EGR installed, verify tubes?
Lifting lug is what it looks like.
Old 03-11-2012, 06:46 PM   #3
PlasticCarsRock
PlasticCarsRock's Avatar
Yeah.
It looks like you may have a leaking cam cover. This is a common problem (Saturn used RTV to seal the cam covers, back then, and they tend to develop leaks after a while). You can now buy a pre-formed rubber gasket to use, instead of RTV (you just need a small dab of RTV on both sides where the timing chain cover meets the head).
Old 03-11-2012, 07:41 PM   #4
TrotFox
1992 SC
2006 VUE 2.4L
Actually, the motor is a replacement according to the po so there's no telling how that cam cover was installed. However, I do not see evidence of a leak in person so I'm just leaving it for now. No oil in the plug holes either.
It at least doesn't leak nearly as much as my Fiero so that one will get the new gaskets first.
Trot, the slippery, fox...
Grey 5spd '06 Vue
Red '15 PriusC-4
Old 03-11-2012, 07:46 PM   #5
The cover is leaking....
Old 03-11-2012, 08:28 PM   #6
PlasticCarsRock
There is a lot of oil near the EGR valve and on the top of the intake manifold. Unless someone has been really careless adding oil, there's a fairly significant leak. If it doesn't consume a lot of oil, it won't hurt anything (and may actually help prevent rust, if it's leaking onto the subframe), but it looks like it could easily account for a significant amount of oil loss between changes.
Old 03-11-2012, 08:43 PM   #7
TrotFox
1992 SC
2006 VUE 2.4L
Roll Eyes Re: JY EGR installed, verify tubes?
Yeah... That would be me. The 5-quart jug plugged harder than I expected and I don't own any simple green yet.
Trot, the messy, fox...
Grey 5spd '06 Vue
Red '15 PriusC-4
Intercooler tubes Revrent Sky Red Line 2 03-04-2011 05:14 PM
hoping to verify it's my starter that's bad lg540 S-Series Tech 9 09-06-2007 03:40 PM
verify rev limit twosaturns S-Series General 11 01-29-2005 07:57 PM
Resale value down the tubes expwyman L-Series General 32 03-22-2003 10:09 PM
