Old 03-09-2012, 12:31 AM   #1
mboydphoto
mboydphoto is on a distinguished road
1993 SL2
Default 1993 Saturn SL2 Speedo jumpy after 65 mph
I've searched the forum before i posted, i didn't find a definitive answer. thats why i'm making this post.
i own a 1993 Saturn SL2 with a speedometer that gets inaccurate once you go about 65mph. it jumps within a 10mph range. so, once i hit 70mph, it jumps from 65-75. it is random, but this is the best description i can give. if i go 80, it usually jumps 75-85. again, that's not 100% all the time. (I've been driving by using gps, or looking at the tach.)
what else isn't working on my cluster. the odometer and the TRIP; I'm assuming that this is a broken gear, i haven't taken it apart to verify. the odometer and trip have been broken for years, and i simply haven't cared enough to fix it.
i spun a bearing and pulled the motor out, had it rebuilt 3 years ago, installed it and everything has since worked as normal. recently, about 2 months ago, that's when the speedometer started getting a mind of its own about 65mph.
my question is, what's causing my speedometer to jump around after 65?
could it be the VSS or something else? i tried to give as much info as i can predict that you'd need.
thanks for you help.
michael
Add to mboydphoto's Reputation
Rate the quality of this post and help mboydphoto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mboydphoto is offline   Reply With Quote
Old 03-17-2012, 05:56 PM   #2
mboydphoto
1993 SL2
Default Re: 1993 Saturn SL2 Speedo jumpy after 65 mph
so, no love? no one has an idea?
Old 03-17-2012, 08:29 PM   #3
These are the gears for the odometer and this may be part of the speedo problem. http://www.odometergears.com/product...eries+91-94/62
Old 04-28-2012, 04:30 PM   #4
6704gto
6704gto is on a distinguished road
6704gto's Avatar
1994 SC2
I have the same problem with my 94 SC2.
'94 SC2 Aqua M5
'67 GTO Mariner Turq M4
'04 GTO Barbados Blue M6
Add to 6704gto's Reputation
Rate the quality of this post and help 6704gto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
6704gto is offline   Reply With Quote
Old 09-07-2015, 07:56 PM   #5
jordy
jordy is on a distinguished road
1992 SL2
2001 SL2
I have the same thing on my 1992 sl2. Sometimes speedometer stops working. Sometimes it goes crazy and the coolant and brake lights flash on and off while its going crazy.
1992 sl2 300,000+
2001 sl2 115,000
Add to jordy's Reputation
Rate the quality of this post and help jordy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jordy is offline   Reply With Quote
Old 09-07-2015, 08:47 PM   #6
SL19302
SL19302's Avatar
2002 SL1
The gears are pricey but worth every penny if you want the odometer and trip meter to function correctly again.
CHECK YOUR OIL!
Add to SL19302's Reputation
2000 Saturn SL Speedo/odometer stopped working after jump demoncamber L-Series Tech 1 05-02-2010 06:35 PM
WTB: 1997 Saturn SC2 DOHC instrument cluster or single speedo jacobs_ladder74 Classifieds 4 04-21-2006 04:35 PM
1993 Saturn SC2 Speedo Safety Mechanism??? Kamikaze S-Series Tech 0 02-27-2006 01:17 AM
jumpy speedometer texlnghorn S-Series Tech 1 05-05-2005 09:18 AM
Jumpy engine green93SL2 Miscellaneous Tech 4 11-04-2000 11:41 AM
