Old 03-08-2012, 08:44 AM   #1
scallhead
scallhead is on a distinguished road
Default 2007 Vue starter noise
Hi,
I know people have experienced starting isues with their Vues but I have an issue that I have not been able to find any threads on so far.
2007 3.5L V6 Vue, starts great every time problem is that it seems as if the starter motor stays engaged for maybe a few seconds after the engine has started. This makes the same noise if you were to try turning the key in the ignition when the engine is already running, a kind of "high pitched chirping noise" that is the best way I can expalin it.
This only happens when the engine is cold and on the first start. Starts fine when the engine is warm or even if I stop and start the engine when cold it starts fine.
Any info or Ideas would be grest because its driving crazy.
Thanks
Add to scallhead's Reputation
Rate the quality of this post and help scallhead reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scallhead is offline   Reply With Quote
Old 03-08-2012, 08:51 AM   #2
mikec
mikec will become famous soon enough
mikec's Avatar
Default Re: 2007 Vue starter noise
It could be the belt slipping on the pulley when it's cold. Does the problem go away when things warm up? My girlfriend has this same problem with her Honda CRV. The dealer could not figure out what it is. Since it only happens on initial startup, she just ignores it.
Add to mikec's Reputation
Rate the quality of this post and help mikec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikec is offline   Reply With Quote
Old 03-08-2012, 08:59 AM   #3
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Sounds like the solenoid and or spring that engages/disengages the pinion gear to the starter ring is hanging up in the cold weather. When you release the key a spring disengages the pinion gear.
Most people replace the starter, but if you are mechanical it is possible you can clean and lubricate this assy to get it to work properly in all temperatures.
I would use all synthetic lubes because of the temperature problem.
Add to BobbyP's Reputation
Old 03-08-2012, 09:10 AM   #4
scallhead
Ok,
I will see what I can do over the weekend, sounds like you could be on to something though. I do not mind getting my hands dirty so I will give it a go.
Thanks for the info
Old 05-16-2013, 07:43 AM   #5
bjcart
bjcart is on a distinguished road
Any luck lubing the old starter? I believe I'm having the same issue and I plan on fixing it today. I may just go get a new starter at advance auto for 95 bucks.
'99 SL2
Add to bjcart's Reputation
Rate the quality of this post and help bjcart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bjcart is offline   Reply With Quote
Old 05-16-2013, 01:52 PM   #6
3RedLines
3RedLines has a spectacular aura about3RedLines has a spectacular aura about
3RedLines's Avatar
2004 VUE Red Line
2004 VUE Red Line
My daughter's did this for a couple of years after I got it. Tore down the starter, lubed the moving parts. No more noise.
Just be sure not to get your grease in the motor part of the starter, it could work its way into the brushes
2007 STS-V
2006 STS 1SC
2005 STS 1SE MRC, ACC, HUD
Add to 3RedLines's Reputation
Rate the quality of this post and help 3RedLines reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
3RedLines is offline   Reply With Quote
Old 05-18-2013, 09:15 AM   #7
bjcart
Well, I ended up buying a refurbished starter from Advance. It was $130 after tax and core credit. I'm very pleased with the results. The Vue cranks much faster and no more noise after start up!
'99 SL2
2007 Installing Remote Starter. Anything I need to get outside of starter package? shaxs Vue General 8 12-25-2011 03:40 PM
2007 Vue steering noise.. what is it? allsaturn Vue Tech 2 12-10-2008 12:57 AM
Starter noise? dcp S-Series Tech 1 11-24-2006 08:11 PM
Strange Starter Noise AceDerry2 S-Series General 4 03-16-2006 10:32 AM
'95 SC1 Starter Noise JettaGL 1.8T S-Series Tech 4 01-05-2004 11:48 AM
