Old 03-06-2012, 05:37 PM   #1
theshackle
theshackle is on a distinguished road
Default best spark plugs?
Hey guys, I'm changing out the plugs in my '95 and '92 SL2's. I've never changed the plugs in them before so I wanted to know when purchasing new spark plugs if there is any particular brand or style that works better with these engines. I used to have an old Crown Vic that would only run right on the factory OE spec Motorcraft plugs and would actually run worse on the high end platinum plugs. I want to make sure that's not the case with the Saturn's 1.9L. Thanks for any advice.
Add to theshackle's Reputation
Rate the quality of this post and help theshackle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
theshackle is offline   Reply With Quote
Old 03-06-2012, 05:40 PM   #2
Default Re: best spark plugs?
NGK BKR5ESA-11 you can order a couple of sets from RockAuto http://www.rockauto.com/ along with a new set of wires cheaper than you can buy them locally. Do not use a fine wire electrode plug. Platinum plugs are fine wire electrode.
Old 03-06-2012, 08:55 PM   #3
ehunter
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
This post will save you a lot of time. Everything is there:
http://www.saturnfans.com/forums/sho...d.php?t=177672
Add to ehunter's Reputation
Considering replacing spark plugs and spark plug wires - Need advice 2002SaturnMan S-Series Tech 25 10-15-2015 07:29 AM
Dealer pricing on spark plug wires and spark plugs. KeithR S-Series General 25 05-19-2011 11:52 PM
1992 SL2: spark, fuel, air, no fire (new air & fuel filter, spark plugs, wires) onixwj S-Series Tech 12 12-11-2009 08:07 PM
Changed spark plugs and wires, look at old plugs (pics) Chingon S-Series General 12 03-30-2005 02:42 AM
Spark Plugs & V-6 SilverNickelQC L-Series General 7 04-22-2003 10:04 PM
