Old 02-25-2012, 03:43 AM   #1
gua742
gua742 is on a distinguished road
Dizzy 2001 SC2 transmission fluid question...
So today a buddy and I did a drain and refill of my 2001 Saturn SC2, it has a manual transmission and the book calls for Dexron III ATF but instead I used Dexron VI ATF, it said on the bottle that you can use Dexron VI in place of Dexron III, but I am just wondering what y'all thinK?
Should I use something else? Will I be ok with Dexron VI?
Thanks in advance, George!
Add to gua742's Reputation
Rate the quality of this post and help gua742 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gua742 is offline   Reply With Quote
Old 02-25-2012, 03:46 AM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: 2001 SC2 transmission fluid question...
USE SOMETHING ELSE!!!
Dexron VI can't be used in the manual transmission. Drain and replace with Dexron III immediately.
2007 Chevy Equinox LT 177K miles
Add to ruley73's Reputation
Old 02-25-2012, 04:06 AM   #3
gua742
What else would I use? It says in the book that the manual transmission used Dexron III and on the bottle it said that Dexron VI was ok to use with other products that call for Dexron III, what should I use?
Thanks! -George
Old 02-25-2012, 04:34 AM   #4
gua742
Default Re: 2001 SC2 transmission fluid question... EXACT PRODUCT I USED...
I used this to fill my manual transmission of my 2001 Saturn SC2 today:
Castrol/1 qt. DEXRON VI premium synthetic blend automatic it called for 2.5 liters.
Premium synthetic blend formula exceeds Dexron-III h requirements. Outstanding sludge resistance provides superior transmission life. Enhanced friction durability improves shifting performance.
Compatible Vehicles/Specifications: General Motors cars and trucks that require Dexron VI. Also satisfies Dexron, Dexron-III H, III, IIE, and II.
So my question is that it exceeds Dexron III specs and it says on the bottle that it can be used in place of Dexron III, so I am just VERY confused. I need some guidance because I REALLY DON'T WANT TO MESS up my girls car. So all your help is greatly appreciated!
Old 02-25-2012, 08:26 AM   #5
Just go drain the transmission and go buy a name brand Universal ATF marked on the bottle Dexron/Mercon compatible this is the replacement for the old now nonexistent Dexron-3. Do not use Dexron - 6.
Old 02-25-2012, 01:10 PM   #6
ruley73
ruley73's Avatar
Read this TSB straight from GM.
Manual Trans Fluid Usage TSB #PIP3836B.pdf
Old 02-25-2012, 09:08 PM   #7
gua742
Happy Re: 2001 SC2 transmission fluid question...
You all rock for answering my questions!
Today I drained and refilled the manual transmission with Dexron III per your comments. I put about 15 miles on the car with the Dexron VI in the manual transmission BEFORE I switched over back over to new Dexron III so I hope I did not screw anything up, could I have?
I am pissed now! I would have NEVER put the Dexron VI in unless it said on the bottle (and it did) that it could take the place of Dexron III, I am going to back to autozone and try to return it!
Thanks for all your help, you all saved my transmission.
Old 02-25-2012, 09:14 PM   #8
jsnead
jsnead is on a distinguished road
2002 SL1
Everything should be ok. That was GMs fault for ever telling anyone that Dexron anything goes back in time. They wrote the TSB a couple of posts above after damage was being done. Another GM fault.
Add to jsnead's Reputation
Rate the quality of this post and help jsnead reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jsnead is offline   Reply With Quote
Old 02-25-2012, 09:40 PM   #9
GM = Government Motors, what do you expect?
2001 LW200 manual transmission fluid change? dbswayne L-Series Tech 15 02-12-2012 05:35 PM
Transmission Fluid Question?? Nick96'SL2 S-Series Tech 12 02-12-2011 08:55 AM
Manual Transmission Fluid On 2001 SL1 motoboymatt S-Series Tech 5 03-16-2010 12:41 PM
Transmission Fluid - 2001 Sc2 01SIlverSc2 S-Series Tech 12 05-03-2007 12:50 PM
Transmission fluid question Sectorshaft S-Series General 26 03-03-2006 05:40 PM
