Astra General Photos
by londonxr3
Astra - Member Photos
229 photos
77 comments
by AstraLover
229 photos
77 comments
by fotc13
229 photos
77 comments
by Charlie
2008 - Astra Road Test
86 photos
7 comments
Old 02-20-2012, 10:17 AM   #1
Digency
Digency is on a distinguished road
2008 Astra XR
Dazed Parking Brake Light turning on
Whenever I make a sharp right hand turn my parking brake light turns on. After a minute the light turns off. I am sure my parking brake is all the way down. Any ideas?
2008 Saturn Astra XR 5 door - Artic White
- Leather trim + Sunroof
- Adv. Audio + Aftermarket Amp + Subwoofer
- Sport Suspension + Stabilitrak
- 18" wheels + tires
- Tint + Armrest + Spoiler
Add to Digency's Reputation
Rate the quality of this post and help Digency reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Digency is offline   Reply With Quote
Old 02-20-2012, 11:47 AM   #2
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
Default Re: Parking Brake Light turning on
Low brake fluid warning is coming on. Time to check the brakes.
Add to ssicarman's Reputation
Old 02-27-2012, 09:13 PM   #3
spencerb
spencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
The light isn't just a parking brake light. It has two purposes. It also indicates a problem with the braking system - low fluid.
2002 L200
2005 Honda Odyssey EX-L
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
Old 02-28-2012, 11:28 AM   #4
Werks11
Werks11 is on a distinguished road
Yepper .......... may want to check the fluid. If it's not the fluid you may want to check the rest of the system.
Parking brake light, thats an inducation you should get out the owners manual and read it.
Add to Werks11's Reputation
Rate the quality of this post and help Werks11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Werks11 is offline   Reply With Quote
Old 02-29-2012, 11:27 AM   #5
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
Yep, if you pull up on the parking brake while driving, the car will "ding" at you too, so it's not a parking brake issue.
Drives: Black Astra XR5 manual
Past Cars: 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Wife's Car: 12 Enclave
http://www.fuelly.com/driver/emg77/astra - 29.3 MPG
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Old 04-12-2012, 04:28 PM   #6
some_phenom
some_phenom is on a distinguished road
I had the same problem. I had to have my rear breaks completely re-built. My mechanic said the breaks were a poor design on GM's part.
Add to some_phenom's Reputation
Rate the quality of this post and help some_phenom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
some_phenom is offline   Reply With Quote
Old 04-13-2012, 10:37 AM   #7
Digency
2008 Astra XR
How much did that cost you?
Old 04-13-2012, 02:10 PM   #8
99blacktop
99blacktop is on a distinguished road
99blacktop's Avatar
A couple years back, I complained that the rear brakes on my car seemed to grind all the time, like burning off the rust after a wet night, but all the time. They put new rotors/pads on the back for me, under warranty.
Here are the part numbers from the receipt:
Part #09117772 "ROTOR SET" Getsaturnparts.com says $134.47
Part #93193613 "PAD KIT, R" Getsaturnparts.com says $100.68
It didn't cost me anything, other than leaving my car overnight because they only had one rotor in stock and couldn't get another one from a neighboring dealer until the next morning. The tech showed me the hassle it was to take the parts off, so I was nice and left my car there so he didn't have to put it back together and then take it apart again.
They were quiet for awhile, but now they have that same grinding noise when I brake. They make more noise than the still factory original brakes on my SC2, 14 years, 120,000 miles, and they don't grind, nor squeal.
2013 Chevy Cruze Eco
2001 Chevy Corvette
My Saturn history:
1993 SL2 100,406 miles ('94-'98)
1999 SC2 118,537 miles ('98-'12)
2005 VUE 25,705 miles ('05-'09)
2008 Astra 27,014 miles ('09-'12)
Add to 99blacktop's Reputation
Rate the quality of this post and help 99blacktop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99blacktop is offline   Reply With Quote
Old 04-14-2012, 11:10 AM   #9
vanilla sky
vanilla sky is on a distinguished road
2008 Astra XR
And I say it's time for a new mechanic.
Low brake fluid is an indication that the brake pads and rotors are worn. Low brake fluid is a side effect of brake wear. Check your pads and rotors before you check your brake fluid. You should NEVER add fluid to a brake system without finding out where it went. Brakes are a life or death item on a car. It's the only system that has to fail ONCE to make a car eligible for lemon law litigation in most states.
If any of you were close enough to me that I could check out your car for you, I'd be happy to. These cars are really basic cars and are fairly simple to work on. It seems like the only people that complain about these cars have owned Japanese cars that they threw away when they needed repairs.
Add to vanilla sky's Reputation
Rate the quality of this post and help vanilla sky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vanilla sky is offline   Reply With Quote
Parking brake light switch chillin05VUE Vue Tech 3 10-01-2011 11:58 PM
parking brake light vintagegz Ion Tech 5 11-18-2008 07:31 AM
Parking Brake Light Shenanigans Outlook General 1 10-21-2007 09:59 AM
Parking light works, brake light doesn't... kevinkawa Ion General 2 04-26-2007 05:28 PM
parking brake light always on... sc2dave S-Series Tech 4 05-29-2005 12:13 AM
