Old 02-12-2012, 01:35 AM   #1
rgrafton
rgrafton is on a distinguished road
rgrafton's Avatar
2002 SC1
Default recommended spark plug
could someone provide the part number of the NGK copper spark plug that is recommended for my 1998 Saturn SW SOHC
i don't mind spending some money as well if there are some better copper spark plugs that are out there... I see these NGK V-power ones, but not sure if they are in the "recommended spark plug list"
2002 SC1 5 speed 140k miles
1994 SL 5 speed 150k miles on engine (250k+ miles on car, tranny...etc.)
Add to rgrafton's Reputation
Rate the quality of this post and help rgrafton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rgrafton is offline   Reply With Quote
Old 02-12-2012, 04:33 AM   #2
Chazberry
Chazberry's Avatar
Default Re: recommended spark plug
You want the BKR5ESA-11 (aka 5643)
Add to Chazberry's Reputation
Old 02-12-2012, 05:08 AM   #3
Chazberry
Chazberry's Avatar
CORRECTION - make that BKR4ESA-11 (aka 7755)
Old 02-12-2012, 05:31 AM   #4
DG3
DG3 is on a distinguished road
DG3's Avatar
NGK Stock #5643 is for the BKR5ESA-11 for the DOHC plugs
NGK Stock #7755 is for the BKR4ESA-11 for the SOHC plugs
Add to DG3's Reputation
Rate the quality of this post and help DG3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DG3 is offline   Reply With Quote
Old 02-12-2012, 11:24 AM   #5
Signmaster
Signmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to beholdSignmaster is a splendid one to behold
Quite a few people use the V power plug as well. I'm running the Denso plugs in our SOHC, and there are a number of users running other brands as well. I know some members run Champion plugs, but not sure if any of them have the SOHC engines.
The NGK numbers get tossed around as they were OEM in some cars, but you can use a variety of different plugs if you want. Other than avoiding the fine wire platinum plugs that some have had issues with, you probably won't notice much of a difference brand to brand.
On this forum often the "recommended" list is simply a part number that got repeated 20,000 times and is thus taken as the best and/or only valid part. Keep in mind that saying something 20,000 times doesn't always make it correct. I've seen posts over and over that say NGK was the OEM plug on my car. Being I pulled AC Delco plugs out, and the representative that works at NGK agrees that AC Delco was still making their own plugs at that time, I tend to think it's just incorrect information being repeated until most people take it as facts.
Old 02-12-2012, 11:43 AM   #6
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Here is the list from Denso...
http://www.globaldenso.com/cgi-bin/g...&action=search
Two questions...
First - why do the plugs numbers change at 99's?
Second - what is the best plug type? I am assuming the Iridium (first column), but y'all are smarter than me...
Old 02-12-2012, 03:10 PM   #7
Signmaster
I have no idea why the designations changed at '99 plugs. It looks as though all the part numbers might have just changed, but it could be a physical change as well. I got the old part number plugs not that long ago, so it could be something recent.
As for "best" that could be debated for years. I use the standard plugs and they provide good life in this car. The single cammers are so easy to change plugs on that I personally don't see much benefit even if another plug type does give longer life. People wishing to lengthen maintenance intervals might benefit from a double platinum or irridium plug.
Old 02-12-2012, 03:35 PM   #8
The number is different because Denso decided that you should be using thier super double platinum plug.
Stick with the NGK BKR5ESA-11 or BKR4ESA-11 and you will be fine.
Old 02-12-2012, 03:39 PM   #9
All plug manufacturers are changing over to a stock number system instead of the letter-number system that has existed since the first sparkplug. Seems computers are too dumb to deal with a random collection of letters and numbers that may not be quite unique across brands. For example several manufactures have had a plug marked A-6 but they are far from the same physically or electrically.
Old 02-12-2012, 03:50 PM   #10
Signmaster
The letter/number designation changed for all plug types. You should look at the link before deciding there is a sinister motive.
Old 02-12-2012, 04:00 PM   #11
I actually did...jerk
Old 02-12-2012, 04:05 PM   #12
Every manufacturer is revising their nomenclature for data access reasons.
Old 02-12-2012, 04:24 PM   #13
Signmaster
Amazing how you could actually click the link and look at it, yet come up to two statements that obviously don't apply.
The above suggests they are leading a person to a certain plug type, when in reality they changed their part letter/number designations on all plug types.
Once again, if you actually look at the link you can see that they changed both stock numbers and the letter/number designation. And there is still a change in plug types beyond a certain year.
As for the "jerk" thing, if you want to reduce yourself to kid stuff because I'm entitled to an opinion, go right ahead. Maybe you should post your cute little troll picture next.
Old 02-12-2012, 04:31 PM   #14
Keep on Trolln troll.
Old 02-12-2012, 04:32 PM   #15
rgrafton
rgrafton's Avatar
2002 SC1
just wondering because 2 years ago i went to ACDelco 41-808 platinum plugs ($7.00 each/ the "BEST" option according to AdvanceAuto's computer) I've heard the stock copper plugs are best so I think I'm going to go with the NGK 7755..
they come up as Nickel Plugs with copper core... Is this right?
do you think I'm alright with the ACDelco or should I go ahead and switch to the coppers and be done with it. I am trying to diagnose why I've been getting 28mpg highway. I've heard I shoudl be getting mid 30s
Old 02-12-2012, 04:45 PM   #16
brags
brags will become famous soon enoughbrags will become famous soon enough
1996 SL1
i have used AC delco plugs before. but switched to nascar double platinum s/plugs made by AutoLite i personally think there better in the sense that engine performance and starting can be felt over the other ones sorry i dont
no the part # because i usually look up the # when i go in the store to buy them
" Any man that doesen"t share his knowledge in cars is wrong to do !"
Add to brags's Reputation
Rate the quality of this post and help brags reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brags is offline   Reply With Quote
Old 02-12-2012, 04:47 PM   #17
Signmaster
All the "standard" plugs are nickel plugs. That is the correct plug number if you want to go the standard NGKs.
Many of the parts place system will try to guide you to the more expensive plugs. Some claim longer life with them, others say it doesn't matter. Several people including myself have run "standard" plugs for 50,000 plus miles without problem, so I don't see any value in the more expensive plugs myself.
So regular NGK, V Power, Denso regular, Autolite regular, AC Delco regular, Champion regular.... you get the picture. All of them will work fine. I don't know if any other regular members have used the AC Delco platinums, so getting feedback on that particular plug might be harder than with some others.
A number of people have had issues with the single platinum plugs as well as the fine wire platinum plugs and in the case of the later especially Bosch platinum fine wires.
If you do a search for posts by NGKtech he lists a number of companies that made OEM plugs for these cars. Any of them were good enough to ship in the cars, so they should remain just as good later in life.
Old 02-12-2012, 05:01 PM   #18
Signmaster
rgrafton,
Here is one of the posts I was looking for.
http://www.saturnfans.com/forums/sho...&postcount=258
The poster actually works for NGK and has answered some tech support issue questions from people on this forum in the past. I'd personally consider his input as the best "horses mouth" we have on the forum in regards to plugs and the NGK plugs in particular.
He also clarifies the copper vs nickel statement towards the end of that post.
Old 02-12-2012, 06:37 PM   #19
saturnsctwo
the words platinum & saturn don't mix at all.
Old 02-12-2012, 06:45 PM   #20
mattwithcats
Could it be because of the engine changes in the 1999 + model years?
From Wikipedia,
"1999 models received improvements to both SOHC and DOHC engines that did not affect power output, but did smooth out some of the harshness associated with them. These changes included revised pistons, connecting rods, crankshaft counterweights, etc. Fuel economy of these refined models also saw a measurable improvement."
http://en.wikipedia.org/wiki/Saturn_S-Series
I have a 98 Sl2 , it runs a little rougher than my Dads 2000 SL2, but it feels like it has more power.
Has anyone swapped a .605 MP2 5th gear into a 1999+ SL2?
Recommended spark plugs for Honda 3.5L V6 L66 Engine Dante Vue Tech 5 08-12-2015 08:25 PM
What are the recommended spark plugs for 3.5? Anjey Aura General 3 04-09-2011 12:07 PM
Which plug is recommended for 95 SW2? citygreen S-Series Tech 4 06-12-2010 02:15 PM
1998 sl2- oil where the spark plug boot meets the spark plug in 1st cylender scrapmedallord S-Series Tech 7 08-14-2009 11:31 PM
recommended brand for spark plug wires? alejohome S-Series Tech 21 07-01-2009 03:24 AM
