Old 02-09-2012, 05:27 PM   #1
Kingstonlake
Kingstonlake is on a distinguished road
2008 AURA XE
Default Oil leak from filter area
Getting a rather substantial oil leak from the filter (housing) area on 2008 3.5L. Especially while car is warming up in the morning. replaced the filter twice now but it still leaks. It seems to be coming from above the filter. Is it possible the housing is leaking and is it replaceable? Any thoughts? Thanks in advance!!
Add to Kingstonlake's Reputation
Rate the quality of this post and help Kingstonlake reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kingstonlake is offline   Reply With Quote
Old 02-09-2012, 05:56 PM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: Oil leak from filter area
part of rubber gasket come off old filter and is stuck????
Add to onefunkar's Reputation
Old 02-10-2012, 12:10 AM   #3
greenman
2009 AURA XE
There's an oil filter adapter on that engine & it's that gasket that usually leaks.
Add to greenman's Reputation
Old 02-10-2012, 09:54 AM   #4
Kingstonlake
2008 AURA XE
No, checked for that.
Old 02-10-2012, 09:57 AM   #5
Kingstonlake
2008 AURA XE
I'm having a very hard time finding a diagram of the 3.5L for the housing or adapter area. found a couple 3.6L schematics but thats a totally different engine if I remember correctly. Is the adapter readily available and fairly straight forward in removal?
Old 02-10-2012, 10:11 AM   #6
Kingstonlake
2008 AURA XE
Adapter gasket on a 2006 Malibu 3.5L, have a feeling this may be what I'm looking for.
Old 02-10-2012, 02:16 PM   #7
greenman
2009 AURA XE
http://www.saturnfans.com/forums/att...1&d=1328901318
Remove the oil filter adapter heat shield nuts.
Remove the oil filter adapter heat shield (2).
Remove the oil filter adapter bolts.
Remove the oil filter adapter (1) and gasket.
Old 02-10-2012, 06:29 PM   #8
Kingstonlake
2008 AURA XE
Excellent, thanks!
Old 02-10-2012, 11:15 PM   #9
greenman
2009 AURA XE
I don't know why but it's a fairly common leak source.
Water Leak in front passenger and driver area.. essenceofsoul24 L-Series Tech 30 04-16-2017 09:37 PM
Filter leak? Phreakish Astra Tech 6 05-03-2010 10:51 AM
leak in plastic area under upper radiator hose intake. technopop L-Series Tech 0 06-28-2007 02:00 PM
Leak from auto trans, Upper Pan area???? Fricken eh! S-Series General 5 10-20-2005 03:36 PM
Leak from roof area? Angry_Inch S-Series Tech 14 09-28-2005 06:22 AM
