Old 02-05-2012, 08:21 AM   #1
badbobby
badbobby will become famous soon enoughbadbobby will become famous soon enough
Default a good code reader
Ready to buy a code reader--looking for one that will give codes and mpg that dosen't cost an arm and a leg---
This will be for 1997 saturn sl sedan manuel shift. Where to buy and approx. cost.
Add to badbobby's Reputation
Rate the quality of this post and help badbobby reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
badbobby is offline   Reply With Quote
Old 02-05-2012, 11:26 AM   #2
BigSmitty
BigSmitty is on a distinguished road
BigSmitty's Avatar
Default Re: a good code reader
Look up the "PLX Kiwi MPG Gauge OBDII Scanner" I don't have enough posts yet to post links . I saw it on StreetRays . com. For $89.59
It does:
OBD2 codes (obviously)
Fuel Used (Gallons, Liters)
Fuel Remaining (Gallons, Liters)
Distance to Empty (Gallons, Liters)
Engine RPM
Vehicle Speed (MPH, KMH)
Coolant Temp (Fahrenheit, Celsius)
Throttle Position
Looks like it may be what your looking for. Hope this helps!
Add to BigSmitty's Reputation
Rate the quality of this post and help BigSmitty reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BigSmitty is offline   Reply With Quote
Old 02-05-2012, 11:38 AM   #3
badbobby
It does:
Engine RPM
Throttle Position
Thanks--I will check it out.
Old 02-05-2012, 11:53 AM   #4
These work and are low cost. http://www.diydiagnostics.com/index.html
Old 02-05-2012, 12:10 PM   #5
I use the old fashioned odometer to calculate my MPG's and a Actron 9180 for everything else.
Old 02-05-2012, 12:15 PM   #6
westwind999
westwind999 will become famous soon enough
1999 SW1
I've used both Ultraguage and Scan Guage II. Both work well.
Add to westwind999's Reputation
Rate the quality of this post and help westwind999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
westwind999 is offline   Reply With Quote
Old 02-05-2012, 07:52 PM   #7
RobertGary1
RobertGary1 is just really niceRobertGary1 is just really niceRobertGary1 is just really niceRobertGary1 is just really niceRobertGary1 is just really nice
1996 SC2
http://bowserelectronics.com/ reads GM specific data, ABS, SIR, etc.
Old 02-06-2012, 10:36 AM   #8
porphyre
porphyre has a spectacular aura aboutporphyre has a spectacular aura about
2001 SL2
The Harbor Freight tool is pretty good.... for the price.
http://www.harborfreight.com/automot...ner-98614.html
I wouldn't pay $150 for it, but I found it on sale at my store for $99. 20% coupon off that put it in my cart for $70 + tax.
However, many people say the OEM version of the tool is the Autel 509. They look exactly the same and the feature breakdown is the same. Googling shopping for the Autel unit shows prices anywhere from $57 to over $100. Amazon has it at $72 shipped.
http://www.auteltech.com/ms509.htm
The tool does all the basics well. The O2 sensor test is useful, if you know how to use it, b/c the user manual sucks.
Add to porphyre's Reputation
Rate the quality of this post and help porphyre reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
porphyre is offline   Reply With Quote
Old 02-06-2012, 03:30 PM   #9
MCR661
MCR661 is on a distinguished road
2002 SC1
I use an Actron 9185. Works just fine.
Add to MCR661's Reputation
Rate the quality of this post and help MCR661 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MCR661 is offline   Reply With Quote
Old 02-06-2012, 03:33 PM   #10
RobertGary1
1996 SC2
Still seems like a lot of pay for a basic reader without support for Air bag, ABS, etc.
-Robert
Old 02-06-2012, 11:18 PM   #11
porphyre
2001 SL2
-Robert
I dunno. Is it? I've got no frame of reference. It pulls codes, live data off all the sensors, graphs, and can output a saved data stream to a PC graphing package. Pulls OBD readiness monitors and can initiate tests on O2 and EVAP systems.
I've got $70 worth of use out of it.
Old 02-07-2012, 01:31 AM   #12
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Ultragauge Or Actron 9145 (number may be wrong)
Ultragauge is nice, give readout of six items (water temp, mpg, timing advance, etc) on the screen.
You need a 96 or higher (OBD II) to use either...
Old 02-07-2012, 08:34 AM   #13
saturn1984
saturn1984 is on a distinguished road
Do any of the lower-cost scantools provide bi-directional capability? For example, to turn a given output on/off ... like a trans shift solenoid, etc?
Add to saturn1984's Reputation
Rate the quality of this post and help saturn1984 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn1984 is offline   Reply With Quote
Old 02-07-2012, 09:32 AM   #14
Device control addresses are vehicle specific and licensed material. The license costs 7000+. If you want that then you will be spending better than 1000.00 for the unit. Only Tech-2 has the complete set for each vehicle and that does not include the Chinese copy.
Old 02-07-2012, 09:32 AM   #15
porphyre
2001 SL2
Sub $100? No.
Sub $200? None that I know of (but I don't know everything)
The one I'm looking into right now costs around $500. It's the PC based AutoEnginuity system. $250 for the software and cables, $225 for the GM access package. According to their list, it will do nearly everything a GM brick will do for Gen3 S-Series. ABS, SRS, all the body controls, A/C, cluster, etc, chassis sensors, powertrain, transmission... OnStar. Totally bi-directional.
Old 02-07-2012, 09:58 AM   #16
Access to the CAN network cars gets you the basic and extended engine code set, ABS, SDM, BCM. It still does not provide settings modification or device control. It provides exactly the minimum that is required by to original Federal law and associated regulations, nothing more. The OBD-2 pre CAN cars require separate data sets for the ABS and SDM which is only minimally available for Saturn. GM is not Saturn so resist strongly falling into that trap.
Old 02-07-2012, 12:25 PM   #17
porphyre
2001 SL2
Agreed. Make sure the potential purchase specifically supports Saturn.
Autoenginuity does...
http://www.autoenginuity.com/GM-Vehi...port-List.html
http://www.autoenginuity.com/GM-All-Systems-List.html
Old 02-07-2012, 01:13 PM   #18
There are several that do support the S-Series but you have to actually cal them on the phone and specifically ask if you can access ABS and SDM codes. Most of the time the answer is NO.
Old 02-07-2012, 01:58 PM   #19
RobertGary1
1996 SC2
I get ABS and SIR with bowserelectronics.com. They do have the ability to send device controls but you have to manually enter the address (which perhaps gets around some of the licensing). I've sent a couple commands just to ensure that I can but haven't really found any reason yet to send commands. You do pay extra for the GM extensions though.
-Robert
Old 02-07-2012, 02:22 PM   #20
RobertGary1
1996 SC2
That's a very impressive product!
-Robert
Looking for good OBD II or OBD II/III reader Matt42 S-Series Tech 7 06-28-2012 09:08 AM
ABS Code Reader for gen-2? madpogue S-Series Tech 7 08-08-2008 02:07 PM
what's a good cheap code reader? dmc S-Series Tech 20 07-22-2007 09:33 AM
A good basic code reader? cybrsk8r S-Series General 7 03-28-2004 11:07 PM
Good OBD I and II reader 2000 SL 1.9 S-Series Tech 13 09-27-2002 09:36 AM
