Old 01-31-2012, 07:48 PM   #1
Maintenance Man
Maintenance Man is on a distinguished road
Default Shift Lock Cable And Key Sticking
New problem with my daughters 02 SL2. She says that she can't get the key out of the ignition unless she slams the shifter in and out of Park. I read something on the web about the shift lock cable needing to be adjusted to fix this problem. It said something about removing the console to get at the cable. First of all how do I go about removing the console and what is the proper procedure for adjusting that cable. Thanks.
Add to Maintenance Man's Reputation
Rate the quality of this post and help Maintenance Man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maintenance Man is offline   Reply With Quote
Old 01-31-2012, 08:15 PM   #2
Default Re: Shift Lock Cable And Key Sticking
Once you get at it spray the console end off with brake cleaner and then lube with powdered mica.
Old 01-31-2012, 08:19 PM   #3
aaron95sl2
aaron95sl2 is on a distinguished road
aaron95sl2's Avatar
I broke mine off at the shifter intentionally so I'd never have to worry about it again. Nothing like being in a hurry and not being able to get the car out of park or the key out.
1995 SL2 | Fully loaded | 165k on odometer |30k on new engine w/ KB-S pistons - not a single drop of oil lost so far!
Add to aaron95sl2's Reputation
Rate the quality of this post and help aaron95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aaron95sl2 is offline   Reply With Quote
Old 01-31-2012, 08:26 PM   #4
There are 2 screws at the front of the console and 2 at the lower rear. Pull up switches and cup holder and drop through hole, then lift it straight up and off. The arm rest has to come off and there are 2 screws on the sides at he rear. The lift up rear slightly and push to the rear to remove.
Old 01-31-2012, 08:28 PM   #5
That is fine for people who are aware of what they are doing. They installed clutch safety switches because people drove through the end of many garages.
Old 01-31-2012, 08:56 PM   #6
aaron95sl2
aaron95sl2's Avatar
And this is why I support stricter driver testing and licensing.
Old 01-31-2012, 09:57 PM   #7
Testing and licensing does not address attention to detail.
Old 01-31-2012, 10:36 PM   #8
The engine still won't start in gear. The shifter / key lockout is a security feature, not a safety device. And for anyone who's really serious about stealing your car, it's not much of a security feature. Depends on whether the OP and driver are concerned about the shifter being moved with the key out.
Add to madpogue's Reputation
Old 01-31-2012, 10:57 PM   #9
The actual purpose is to force you to put the car in Park before retrieving the key. The safety here is the unoccupied roll away event. Just like the brake shift interlock prevents selecting reverse or drive without the brake applied and running into the trash cans.
The starter interlock was just an example.
The early theft protection was fixing it so the key was locked into the ignition unless the ignition was in off.
All designed to irritate the experienced driver.
Old 02-01-2012, 06:54 PM   #10
Maintenance Man
Thanks OldNuc. When she brings the car on her next day off I'll try the brake cleaner but where do you get powdered mica ?
Old 02-01-2012, 10:35 PM   #11
The quickest place to find it is a gun shop that sells reloading supplies or http://www.ebay.com/itm/1-OZ-PEARL-W...item255f654908 You can find it at art supply stores usually, may have to try several Dick Blick usually has it. http://www.dickblick.com/
Old 02-02-2012, 12:26 AM   #12
Maintenance Man
I have no idea what it would be used for concerning firearms but there's a gun shop about three blocks from here. What can I tell you, this is Texas ! It's like pizza joints in New York, there's one on almost every corner.
Old 02-02-2012, 12:43 AM   #13
Powdered mica is used as a high pressure lubricant when resizing cases. As you can tell it is also in paint, concrete mold release, makeup and cosmetics, soap, and several others that I forgot.
Old 02-02-2012, 04:06 PM   #14
dbert513
dbert513 is on a distinguished road
Here's the procedure for adjusting the cable... hope it helps. I have the procedure for removing the console, but the file is too big. It's an easy thing though....
Add to dbert513's Reputation
Rate the quality of this post and help dbert513 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbert513 is offline   Reply With Quote
Old 02-03-2012, 01:02 AM   #15
Maintenance Man
Thank you dbert513. I always like to know ahead of time what to look for before digging into something I haven't done before. I'm going to try oldnuc's suggestion first and if that's not enough to fix it I'll do the cable adjustment. I was going to buy the soft cover Hayne's book on this car a long time ago but they're not very concise and just breeze over stuff.
Old 02-03-2012, 02:35 AM   #16
Haynes probably does not even mention this little issue. You will find that all of those coffee lattes that got spilled are in the mechanism under the console. Hence the initial recommendation to clean the gunk out first. Chocolate, milk, steamed milk, and sugar are lousy lubricants. Add a couple of sodas and you have a real mess.
Old 02-04-2012, 07:23 AM   #17
Maintenance Man
My daughter came over today for us to go and get new tires put on her car and several other errands so I didn't have enough time to mess with the cables. Besides for the fact that we were having a real frog choker of a rain storm. Going by debert513's PDF I popped out the forward cup holder and saw the cable junction. Simple enough. It was clean and just a little dusty. She'll be back over in a few days for me to dig into it.
Old 02-01-2018, 06:31 PM   #18
kmcn
kmcn will become famous soon enough
Just to clarify how the "solenoid" works. It's actually an electromagnet! It gets power from the ignition circuit and when you depress the brake it opens the ground side of the solenoid, so it disengages. It is reactivated any time you take your foot off the brake, but it won't re-engage until the metal inside gets close enough to the electromagnet inside, which only happens when you put the shift lever back in park. This electromagnet is what prevents you from shifting out of park, unless the brake pedal is pressed.
If you can't turn the key back to 'lock' and remove the key, that's the cable adjustment that was previously posted. It is very easy to do.
Add to kmcn's Reputation
Rate the quality of this post and help kmcn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kmcn is offline   Reply With Quote
cable adj. for ign lock.... TwinRevver S-Series Tech 3 02-11-2008 07:14 PM
key stuck, park lock cable?? liz11990 S-Series Tech 5 01-03-2008 10:48 PM
Sticking rear hatch lock zaphod4239 Vue Tech 0 03-06-2007 09:56 PM
Park-lock or ignition-lock cable adjustment... Dach Miscellaneous Tech 2 11-25-2002 10:55 PM
