Old 01-26-2012, 08:23 PM   #1
imboden
imboden is on a distinguished road
2009 VUE 2.2L
Default 2009 Vue hood NOT closing
So looking around these forums, I've seen many issues about the hood not opening. Well my issue is the opposite.
This morning I popped my hood to refill the windshield washer fluid, afterwards, my hood would not close. Well not completely. See, the latch you release from out side (I'm going to call the safety latch for lack of better terms) will hold. But the main latch will not. I was able to move the latch with the use of a screwdriver and putting some of my body weight on it.
After work, I stopped at Canadian Tire, picked up a can of WD40 and soaked the latch. The main latch will now kind of hold, but I can release it with very little pressure from outside.
It seems I have these issues when ever I open the hood for any reason. Under warranty, I had that latch replaced twice since buying new in January 2009.
Add to imboden's Reputation
Rate the quality of this post and help imboden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
imboden is offline   Reply With Quote
Old 01-27-2012, 08:57 AM   #2
Sweepspear
Sweepspear is on a distinguished road
Sweepspear's Avatar
2008 VUE 3.6L
Default Re: 2009 Vue hood NOT closing
I had that same issue with our '08 VUE.
We were heading out of town on a trip, and as I am driving down the interstate I noticed the hood was popped.
Pulled off, and after repeated closing & slamming, I was able to get it to catch.
I was afraid to ever open it again.
I did though, and like you lubricated the heck out of it. No problem since.
But, it does seem like the latch opening cable has more slack in it than it should. I think it stretched.
Now when I close it I really give it a tug to see if it is latched.
Dale
I’m no longer going to pursue my dreams. I’m just going to find out where they are going and hook up with them later.
Add to Sweepspear's Reputation
Rate the quality of this post and help Sweepspear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sweepspear is offline   Reply With Quote
Old 01-27-2012, 09:14 AM   #3
imboden
2009 VUE 2.2L
It seems like though, any time I open my hood, I have this same issue. It really makes no sense. And because of this, I have the hood open sensor giving me a message on the screen on my dash, and my remote start don't work. So what the hell....
Old 01-27-2012, 09:32 AM   #4
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
Perhaps the mechanical hood latch apparatus does not have a problem.
Check for the rubber bump-stops on each front corner of hood (or could be on the front fender/radiator support structure).
Many times these "stops" are adjustable by turning CW or CCW.
I'd suggest turning each "stop" a few turns to determine if "stop" height changes.
You could be back in business after a few CW turns of all stops.
Keep in mind you may have to compromise between smooth closures and maintaining correct spacing between hood and fender.
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
Old 01-28-2012, 10:31 AM   #5
SC2BuzzBomb
SC2BuzzBomb is on a distinguished road
Wow, I can't believe a vehicle only three years old is having such problems. Isn't the vehicle still under warranty? GM should pick up the repair bill.
Add to SC2BuzzBomb's Reputation
Rate the quality of this post and help SC2BuzzBomb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC2BuzzBomb is offline   Reply With Quote
Old 01-28-2012, 10:43 AM   #6
imboden
2009 VUE 2.2L
The dealer has looked at that many times, those stops are as far down as they will go
It has been in many times since I bought the vehicle brand new in January 2009. Warranty expired 12000km ago.
Old 01-28-2012, 11:51 AM   #7
far2grumpy
far2grumpy's Avatar
Are you interested in service manual extracts to adjust the hood latch assembly?
I'd typically post without asking but you mentioned the dealer had replaced twice under warranty.
Old 01-28-2012, 11:54 AM   #8
imboden
2009 VUE 2.2L
I think my email is on my profile. If you want to send them there, sure.
Hood Dents Easily 2009 Saturn Vue CreekVue Vue Tech 4 01-24-2012 12:26 PM
Saturn canada closing dec 31/2009 letter kbg1 Support Forum for Canadian Saturn Owners 30 01-11-2010 06:19 PM
Saturn of Indianapolis -- Closing October 30th, 2009 EricSaturnSC2 General Saturn Discussion 4 10-27-2009 04:14 PM
Hood release cable crimped, hood stuck in a released state Cards Ion Tech 3 01-06-2009 05:05 PM
L200 hood not closing JGazra78 L-Series Tech 0 10-21-2007 08:34 PM
