Old 01-26-2012, 04:55 PM   #1
Elemntsk8r16
Elemntsk8r16 is on a distinguished road
Default Coolant light
So my gf has a 2005 Saturn ion-2 and her coolan light keeps coming on within minutes after startup. Iv looked at it, a mechanic has looked at it, can't seem to figure it out. Is this a normal problem with Saturn ions? Need some advice here on what the problem might be or where to start.
Thanks!
Add to Elemntsk8r16's Reputation
Rate the quality of this post and help Elemntsk8r16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Elemntsk8r16 is offline   Reply With Quote
Old 01-26-2012, 05:42 PM   #2
Default Re: Coolant light
Low on coolant and needs topping off? Often if coolant hasn't been replaced with a complete flush then old coolant eventually precipitates and builds up on the float that dips lower into the coolant. While coolant may look filled to the level mark the float drops a little lower and turns on the low coolant indicator.
Either drain and flush the cooling system or top off about an inch higher than the full mark.
Old 01-27-2012, 12:56 AM   #3
Elemntsk8r16
Yeah maybe I should double check her reciept n make sure she got a flush. She told.me she did but idk I don't trust most places anymore. Ill double check all that but last I knew that was all fine.
Old 01-27-2012, 05:26 AM   #4
2006 ion2
2007 ION-2 Sedan
Usually this is because the .sensor is gummed up and you need to replace the tank. Few have been able to clean it, and none to my knowledge have been able to "fool" it like fdryer suggests.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 01-30-2012, 10:17 AM   #5
jcc007
jcc007 is on a distinguished road
2006 ION-2 Quad Coupe
Sounds like your low coolant light is from your radiator reservoir.. I cleaned mine out and worked like a charm..
http://www.youtube.com/watch?v=-5814...e_gdata_player
Add to jcc007's Reputation
Rate the quality of this post and help jcc007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcc007 is offline   Reply With Quote
Old 01-30-2012, 11:35 AM   #6
2006 ion2
2007 ION-2 Sedan
on ions, cleaning seems less common to work. not that one shouldn't try, it's just not guaranteed to work.
2007 Saturn Ion 2
Old 01-31-2012, 12:20 AM   #7
bern
2004 ION-2 Sedan
X 2 -- replace the tank
Add to bern's Reputation
Old 02-01-2012, 12:12 AM   #8
Elemntsk8r16
lots of good info here. Thanks a lot! ill let you know if i come across anything.
Coolant light stays on but coolant is at correct level rke5858 Ion Tech 6 01-21-2017 04:14 PM
low coolant level light on but plenty of coolant in reservoir smote S-Series Tech 2 11-11-2008 12:04 PM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 11:56 AM
Coolant light and coolant level light flash after gunning it? FightingChance S-Series Tech 7 10-07-2006 10:03 PM
Low coolant light comming on... but coolant level is fine? joe4324 Miscellaneous Tech 3 12-02-2003 12:26 PM
